A turbulence scheme allowing for mesoscale and large-eddy simulations, Quarterly Journal of the Royal Meteorological Society, vol.28, issue.2, pp.1-30, 2000. ,
DOI : 10.1007/978-94-009-3027-8
Augmented lagrangian methods: Applications to the numerical solution of boundary-value problems, ZAMM -Journal of Applied Mathematics and Mechanics / Zeitschrift für Angewandte Mathematik und Mechanik, pp.65-622, 1985. ,
Schwarz methods over the course of time, Electron. Trans. Numer. Anal, vol.3131, pp.228-255, 2008. ,
On a 2D ???zoom??? for the 1D shallow water model: Coupling and data assimilation, Computer Methods in Applied Mechanics and Engineering, vol.196, issue.45-48, pp.45-48, 2007. ,
DOI : 10.1016/j.cma.2007.05.026
Approximate Gauss???Newton Methods for Nonlinear Least Squares Problems, SIAM Journal on Optimization, vol.18, issue.1, pp.106-132, 2007. ,
DOI : 10.1137/050624935
URL : http://www.reading.ac.uk/web/FILES/maths/09-04.pdf
Simplified and regular physical parameterizations for incremental four-dimensional variational assimilation URL: https://doi.org/10, 127<0026:SARPPF>2.0.CO, pp.26-451520, 1175. ,
Impact of a simplified physical package in 4D-var analyses of fastex situations, Quarterly Journal of the Royal Meteorological Society, vol.124, issue.1, pp.2465-2485, 1999. ,
DOI : 10.1034/j.1600-0870.1998.t01-3-00001.x
Surface Fluxes for Practitioners of Global Ocean Data Assimilation, pp.229-270, 2006. ,
DOI : 10.1007/1-4020-4028-8_9
Oceanic vertical mixing: A review and a model with a nonlocal boundary layer parameterization, Reviews of Geophysics, vol.33, issue.11, pp.363-403, 1994. ,
DOI : 10.1017/CBO9780511608827
Variational algorithms for analysis and assimilation of meteorological observations: theoretical aspects, Tellus A 38A, pp.97-110, 1986. ,
DOI : 10.1007/978-3-642-65024-6
Toward an optimized global-in-time Schwarz Algorithm for diffusion equations with discontinuous and spatially variable coefficients. Part 1: The constant coefficients case, Electron. Trans. Numer. Anal, vol.40, pp.148-169, 2013. ,
Toward an optimized global-in-time Schwarz Algorithm for diffusion equations with discontinuous and spatially variable coefficients. Part 2: The variable coefficients case, Electron. Trans. Numer. Anal, vol.40, pp.170-186, 2013. ,
Fundamentals of Geophysical Fluid Dynamics, 2006. ,
Origin and Impact of Initialization Shocks in Coupled Atmosphere???Ocean Forecasts*, Monthly Weather Review, vol.143, issue.11, pp.4631-4644, 2015. ,
DOI : 10.1175/MWR-D-15-0076.s1
Exploring strategies for coupled 4D-Var data assimilation using an idealised atmosphere???ocean model, Tellus A: Dynamic Meteorology and Oceanography, vol.135, issue.1, p.67, 2015. ,
DOI : 10.1175/MWR3466.1
URL : http://www.tandfonline.com/doi/pdf/10.3402/tellusa.v67.27025?needAccess=true
Estimating Forecast Error Covariances for Strongly Coupled Atmosphere???Ocean 4D-Var Data Assimilation, Monthly Weather Review, vol.145, issue.10, pp.4011-4035, 2017. ,
DOI : 10.1175/MWR-D-16-0284.1
Incremental 4D-Var convergence study', Tellus A, pp.706-718, 2007. ,
