Parallel Code Generation of Synchronous Programs for a Many-core Architecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Amaury Graillat
  • Fonction : Auteur
  • PersonId : 1025221
Pascal Raymond
Embedded systems tend to require more and more computational power. Many-core architectures are good candidates since they offer power and are considered more time predictable than classical multi-cores. Data-flow Synchronous languages such as Lustre or Scade are widely used for avionic critical software. Programs are described by networks of computational nodes. Implementation of such programs on a many-core architecture must ensure a bounded response time and preserve the functional behavior by taking interference into account. We consider the top-level node of a Lustre application as a software architecture description where each sub-node corresponds to a potential parallel task. Given a mapping (tasks to cores), we automatically generate code suitable for the targeted many-core architecture. This minimizes memory interferences and allows usage of a framework to compute the Worst-Case Response Time.
date2018.pdf (150.52 Ko) Télécharger le fichier
hal-01667594 , version 1 (19-12-2017)
hal-01667594 , version 2 (02-03-2018)
Amaury Graillat, Matthieu Moy, Pascal Raymond, Benoît Dupont de Dinechin. Parallel Code Generation of Synchronous Programs for a Many-core Architecture. DATE 2018 - Design, Automation and Test in Europe, Mar 2018, Dresden, Germany. pp.1139-1142, ⟨10.23919/DATE.2018.8342182⟩. ⟨hal-01667594v2⟩
1700 Consultations
984 Téléchargements
