Network analysis and synthesis-A modern system theory approach, 1973. ,
Rational and meromorphic approximation in L p of the circle : system-theoretic motivations , critical points and error rates, Computational Methods and Function Theory, pp.45-78 ,
On Transfer Functions Realizable with Active Electronic Components, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01098616
Minimax principle and lower bounds in <mml:math altimg="si1263.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd" xmlns:sa="http://www.elsevier.com/xml/common/struct-aff/dtd"><mml:msup><mml:mrow><mml:mi>H</mml:mi></mml:mrow><mml:mrow><mml:mn>2</mml:mn></mml:mrow></mml:msup></mml:math>-rational approximation, Journal of Approximation Theory, vol.206, pp.17-47, 2016. ,
DOI : 10.1016/j.jat.2015.03.004
Classical network theory. series in information systems, 1968. ,
Dissipative Systems Analysis and Control, 2007. ,
DOI : 10.1007/978-1-84628-517-2
URL : https://hal.archives-ouvertes.fr/hal-01338369
Wideband circuit design . Electronic engineering systems series, 1998. ,
Network Synthesis with Negative Resistors, Proceedings of the IRE, pp.907-920, 1961. ,
DOI : 10.1109/JRPROC.1961.287934
Active Network Analysis Advanced Series in Electrical and Computer Engineering, 1991. ,
Spurious Poles in Diagonal Rational Approximation, of Series in Computational Mathematics, 1992. ,
Classical Control using H ? methods: an introduction to design, SIAM, 1998. ,
DOI : 10.1137/1.9781611971378
Banach spaces of analytic functions. series in modern analysis, 1962. ,
Closed-loop stability analysis of microwave amplifiers, Electronics Letters, vol.37, issue.4, pp.226-228, 2001. ,
DOI : 10.1049/el:20010170
On relationships among passivity, positive realness, and dissipativity in linear systems, Automatica, vol.50, issue.4, pp.1003-1016, 2014. ,
DOI : 10.1016/j.automatica.2014.02.013
The designer's Guide to Spice and Spectre, 1995. ,
Laguerre and Kautz shift approximations of delay systems, International Journal of Control, vol.72, issue.10, pp.932-946, 1999. ,
DOI : 10.1080/002071799220678
Transform analysis of generalized functions, Mathematics Studies, vol.119, 1986. ,
Identification of microwave filters by analytic and rational approximation, Automatica, vol.49, issue.2, pp.317-325, 2013. ,
DOI : 10.1016/j.automatica.2012.10.005
URL : https://hal.archives-ouvertes.fr/hal-00753824
Linear operators and linear systems. Number 60 in Student texts, 2004. ,
H??? and BIBO stabilization of delay systems of neutral type, Systems & Control Letters, vol.52, issue.3-4, pp.283-288, 2004. ,
DOI : 10.1016/j.sysconle.2003.09.014
Hankel Operators and their Applications, 2003. ,
DOI : 10.1007/978-0-387-21681-2
An improved refinable rational approximation to the ideal time delay, IEEE Transactions on Circuits and Systems I: Fundamental Theory and Applications, vol.46, issue.5, 1999. ,
DOI : 10.1109/81.762930
Microwave Engineering, 2011. ,
Potential Theory in the Complex Plane. Number 28 in London Math. Soc. Students Texts, 1995. ,
DOI : 10.1017/cbo9780511623776
Real and complex analysis, 1982. ,
Check the Stability: Stability Analysis Methods for Microwave Circuits, IEEE Microwave Magazine, vol.16, issue.5, pp.69-90, 2015. ,
DOI : 10.1109/MMM.2015.2410951
Stability analysis of nonlinear microwave circuits, 2002. ,
Operation and Modeling of the MOS Transistor A new approximation method for time delay systems, IEEE Trans. on Automatic Control, issue.7, pp.421008-1011, 1997. ,
