, Pygem: Python Geometrical Morpher
Dakota, a multilevel parallel object-oriented framework for design optimization, parameter estimation, uncertainty quantification, and sensitivity analysis: Version 6.0 user's manual. Sandia National Laboratories, 2014. ,
Nonlinear model order reduction based ,
Reduced-order subscales for pod models, Computer Methods in Applied Mechanics and Engineering, vol.291, pp.173-196, 2015. ,
Closed-loop control of an open cavity flow using reduced-order models, Journal of Fluid Mechanics, vol.641, pp.1-50, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-01021129
An 'empirical interpolation' method: application to efficient reduced-basis discretization of partial differential equations, Comptes Rendus Mathematique, vol.339, issue.9, pp.667-672, 2004. ,
DOI : 10.1016/j.crma.2004.08.006
URL : https://hal.archives-ouvertes.fr/hal-00021702
Enablers for robust pod models, Journal of Computational Physics, vol.228, issue.2, pp.516-538, 2009. ,
DOI : 10.1016/j.jcp.2008.09.024
URL : https://hal.archives-ouvertes.fr/inria-00338203
Reduced order models at work in aeronautics and medicine, Reduced Order Methods for Modeling and Computational Reduction, pp.305-332, 2014. ,
DOI : 10.1007/978-3-319-02090-7_11
An accurate cartesian method for incompressible flows with moving boundaries, Communications in Computational Physics, vol.15, issue.05, pp.1266-1290, 2014. ,
DOI : 10.4208/cicp.220313.111013a
URL : https://hal.archives-ouvertes.fr/hal-00992348
Computational fluid dynamics: principles and applications, 2015. ,
Towards an adaptive pod/svd surrogate model for aeronautic design, Computers & Fluids, vol.40, issue.1, pp.195-209, 2011. ,
DOI : 10.1016/j.compfluid.2010.09.002
URL : https://hal.archives-ouvertes.fr/hal-01298892
Projection-based model reduction for reacting flows, 40th Fluid Dynamics Conference and Exhibit, p.5008, 2010. ,
DOI : 10.2514/6.2010-5008
Iterative methods for model reduction by domain decomposition, Computers & Fluids, vol.38, issue.6, pp.1160-1167, 2009. ,
DOI : 10.1016/j.compfluid.2008.11.008
URL : https://hal.archives-ouvertes.fr/inria-00193962
A numerical investigation of velocity-pressure reduced order models for incompressible flows, Journal of Computational Physics, vol.259, pp.598-616, 2014. ,
A compact proper orthogonal decomposition basis for optimization-oriented reduced-order models, 12th AIAA/ISSMO multidisciplinary analysis and optimization conference, p.5964, 2008. ,
DOI : 10.2514/6.2008-5964
Efficient non-linear model reduction via a least-squares petrov-galerkin projection and compressive tensor approximations, International Journal for Numerical Methods in Engineering, vol.86, issue.2, pp.155-181, 2011. ,
DOI : 10.1002/nme.3050
Nonlinear model reduction via discrete empirical interpolation, SIAM Journal on Scientific Computing, vol.32, issue.5, pp.2737-2764, 2010. ,
DOI : 10.1137/090766498
URL : https://scholarship.rice.edu/bitstream/1911/70218/1/ChaturantabutS.pdf
Pgd-based computational vademecum for efficient design, optimization and control, Archives of Computational Methods in Engineering, vol.20, issue.1, pp.31-59, 2013. ,
DOI : 10.1007/s11831-013-9080-x
URL : https://hal.archives-ouvertes.fr/hal-01515083
, Numerical solution of the navier-stokes equations. Mathematics of computation, vol.22, pp.745-762, 1968.
Numerical simulation of distributed parameter processes, 2013. ,
On continuation of inviscid vortex patches, Physica D: Nonlinear Phenomena, vol.239, issue.3, pp.190-201, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00551885
Predictive inference, vol.55, 1993. ,
A sharp interface immersed boundary method for compressible viscous flows, Journal of Computational Physics, vol.225, issue.1, pp.528-553, 2007. ,
Supg reduced order models for convection-dominated convection-diffusion-reaction equations, Computer Methods in Applied Mechanics and Engineering, vol.289, pp.454-474, 2015. ,
Modeling of transitional channel flow using balanced proper orthogonal decomposition, Physics of Fluids, vol.20, issue.3, p.34103, 2008. ,
Error Analysis and Estimation for the Finite Volume Method with Applications to Fluid Flows, 1996. ,
Openfoam: A c++ library for complex physics simulations, International workshop on coupled methods in numerical dynamics, vol.1000, pp.1-20, 2007. ,
A nonreflecting outlet boundary condition for incompressible unsteady navierstokes calculations, Journal of computational physics, vol.107, issue.2, pp.239-253, 1993. ,
Efficient global optimization of expensive black-box functions, Journal of Global optimization, vol.13, issue.4, pp.455-492, 1998. ,
Simulation of interaction of aircraft with gust and resolved les-simulated atmospheric turbulence, Advances in Simulation of Wing and Nacelle Stall, pp.203-221, 2016. ,
On the unsteady behavior of the flow around naca 0012 airfoil with steady external conditions at re= 1000, International Journal of Micro Air Vehicles, vol.7, issue.3, pp.301-326, 2015. ,
A versatile sharp interface immersed boundary method for incompressible flows with complex boundaries, Journal of Computational Physics, vol.227, issue.10, pp.4825-4852, 2008. ,
A global stability analysis of the steady and periodic cylinder wake, Journal of Fluid Mechanics, vol.270, pp.297-330, 1994. ,
A low-dimensional galerkin method for the threedimensional flow around a circular cylinder, Physics of Fluids, vol.6, issue.1, pp.124-143, 1994. ,
The need for a pressure-term representation in empirical galerkin models of incompressible shear flows, Journal of Fluid Mechanics, vol.523, pp.339-365, 2005. ,
Reduced-order modelling for flow control, vol.528, 2011. ,
On the need for a nonlinear subscale turbulence term in pod models as exemplified for a high-reynolds-number flow over an ahmed body, Journal of Fluid Mechanics, vol.747, pp.518-544, 2014. ,
Numerical heat transfer and fluid flow, 1980. ,
Higamod: A hierarchical isogeometric approach for model reduction in curved pipes, Computers & Fluids, vol.142, pp.21-29, 2017. ,
Boundary conditions for direct simulations of compressible viscous flows, Journal of computational physics, vol.101, issue.1, pp.104-129, 1992. ,
Modeling the heart and the circulatory system, vol.14, 2015. ,
Reduced order methods for modeling and computational reduction, vol.9, 2014. ,
Certified reduced basis approximation for parametrized partial differential equations and applications, Journal of Mathematics in Industry, vol.1, issue.1, p.3, 2011. ,
Model reduction for fluids, using balanced proper orthogonal decomposition, International Journal of Bifurcation and Chaos, vol.15, issue.03, pp.997-1013, 2005. ,
Model reduction for compressible flows using pod and galerkin projection, Physica D: Nonlinear Phenomena, vol.189, issue.1, pp.115-129, 2004. ,
Dynamic mode decomposition of numerical and experimental data, Journal of fluid mechanics, vol.656, pp.5-28, 2010. ,
Free-form deformation of solid geometric models, ACM SIGGRAPH computer graphics, vol.20, issue.4, pp.151-160, 1986. ,
Equationfree/galerkin-free pod-assisted computation of incompressible flows, Journal of Computational Physics, vol.207, issue.2, pp.568-587, 2005. ,
Turbulence and the dynamics of coherent structures part i: coherent structures, Quarterly of applied mathematics, vol.45, issue.3, pp.561-571, 1987. ,
A one-equation turbulence model for aerodynamic flows, 30th aerospace sciences meeting and exhibit, p.439, 1992. ,
Far-field boundary conditions for transonic lifting solutions to the euler equations, AIAA journal, vol.24, issue.7, pp.1074-1080, 1986. ,
Multi-fidelity simulation of a turbofan engine with results zoomed into mini-maps for a zero-d cycle simulation, ASME Turbo Expo, pp.219-230, 2004. ,
Adaptive sampling strategies for nonintrusive pod-based surrogates. Engineering computations, vol.30, pp.521-547, 2013. ,
Proper orthogonal decomposition closure models for turbulent flows: a numerical comparison, Computer Methods in Applied Mechanics and Engineering, vol.237, pp.10-26, 2012. ,
Feedback control by low-order modelling of the laminar flow past a bluff body, Journal of Fluid Mechanics, vol.634, pp.405-418, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00386355
Robust model identification of actuated vortex wakes, Physica D: nonlinear phenomena, vol.238, issue.4, pp.416-427, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00288089
Numerical methods for loworder modeling of fluid flows based on pod, International Journal for Numerical Methods in Fluids, vol.63, issue.2, pp.249-268, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00345184
Balanced model reduction via the proper orthogonal decomposition, AIAA journal, vol.40, issue.11, pp.2323-2330, 2002. ,
Local reduced-order modeling and iterative sampling for parametric analyses of aero-icing problems, AIAA Journal, 2015. ,
