On the observability of linear, time-invariant systems with unknown inputs, Journal of Optimization Theory and Applications, vol.3, issue.6, pp.410-415, 1969. ,
DOI : 10.1007/BF00929356
3 known landmarks are enough for solving planar bearing SLAM and fully reconstruct unknown inputs, 2010 IEEE/RSJ International Conference on Intelligent Robots and Systems, 2010. ,
DOI : 10.1109/IROS.2010.5648896
Observability analysis and active control for airborne SLAM, IEEE Transactions on Aerospace and Electronic Systems, vol.44, issue.1, pp.261-280, 2008. ,
DOI : 10.1109/TAES.2008.4517003
URL : http://www-personal.acfr.usyd.edu.au/m.bryson/publications/Bryson2008_TAES.pdf
Simultaneous Calibration of Odometry and Sensor Parameters for Mobile Robots, IEEE Transactions on Robotics, vol.29, issue.2, pp.475-492, 2013. ,
DOI : 10.1109/TRO.2012.2226380
On Wonham stabilizability condition in the synthesis of observers for unknown-input systems, IEEE Transactions on Automatic Control, vol.16, issue.5, pp.499-500 ,
DOI : 10.1109/TAC.1971.1099766
IMU-RGBD Camera 3D Pose Estimation and Extrinsic Calibration: Observability Analysis and Consistency Improvement, 2013. ,
Nonlinear Controllability and Observability, Transaction On Automatic Control, pp.22-728, 1977. ,
Towards Consistent Vision-Aided Inertial Navigation, Int. Workshop on the Algorithmic Foundations of Robotics, 2012. ,
DOI : 10.1007/978-3-642-36279-8_34
URL : http://www-users.cs.umn.edu/%7Estergios/papers/WAFR-2012-OC-VINS-SLAM.pdf
Camera-IMU-based localization: Observability analysis and consistency improvement, The International Journal of Robotics Research, vol.41, issue.4, pp.182-201, 2014. ,
DOI : 10.1109/ICRA.2011.5980291
Observability-based Rules for Designing Consistent EKF SLAM Estimators, The International Journal of Robotics Research, vol.5, issue.4, pp.502-528, 2010. ,
DOI : 10.1177/027836498600500404
URL : http://www-users.cs.umn.edu/%7Estergios/papers/IJRR-Observability-based-rules-consistency-2010.pdf
A Quadratic-Complexity Observability-Constrained Unscented Kalman Filter for SLAM, IEEE Transactions on Robotics, vol.29, issue.5, pp.1226-1243, 2013. ,
DOI : 10.1109/TRO.2013.2267991
URL : http://www-users.cs.umn.edu/~stergios/papers/TRO_2013_OC_UKF_Paul_Tassos.pdf
Towards consistent visual-inertial navigation, 2014 IEEE International Conference on Robotics and Automation (ICRA), p.2014 ,
DOI : 10.1109/ICRA.2014.6907581
Visual-inertial navigation, mapping and localization: A scalable real-time causal approach, The International Journal of Robotics Research, vol.33, issue.60, pp.407-430, 2011. ,
DOI : 10.1007/s11263-006-9794-4
URL : http://www.vision.cs.ucla.edu/papers/jonesS10IJRR.pdf
Visual-Inertial Sensor Fusion: Localization, Mapping and Sensor-to-Sensor Self-calibration, The International Journal of Robotics Research, vol.10, issue.2, pp.56-79, 2011. ,
DOI : 10.1007/978-0-387-74066-9
URL : http://cres.usc.edu/pubdb_html/files_upload/645.pdf
On the Consistency of Vision-Aided Inertial Navigation, Proc. of the Int. Symposium on Experimental Robotics, Canada, 2012. ,
DOI : 10.1007/978-3-319-00065-7_22
On the Observability and Observability Analysis of SLAM, IEEE/RSJ International Conference on Intelligent Robots and Systems, pp.9-15, 2006. ,
Improving the accuracy of EKF-based visualinertial odometry, 2012. ,
State Estimation Based on the Concept of Continuous Symmetry and Observability Analysis: The Case of Calibration, IEEE Transactions on Robotics, vol.27, issue.2, pp.239-255, 2011. ,
DOI : 10.1109/TRO.2011.2109210
URL : https://hal.archives-ouvertes.fr/hal-00578795
Observability Properties and Deterministic Algorithms in Visual-Inertial Structure from Motion, Foundations and Trends in Robotics, vol.3, issue.3, pp.139-209 ,
DOI : 10.1561/2300000030
Minimalistic sensor design in visual-inertial structure from motion, 2015 IEEE International Conference on Robotics and Automation (ICRA), 2015. ,
DOI : 10.1109/ICRA.2015.7139656
URL : https://hal.archives-ouvertes.fr/hal-01248785
Nonlinear Unknown Input Observability: Analytical expression of the observable codistribution in the case of a single unknown input ,
DOI : 10.1137/1.9781611974072.2
URL : https://hal.archives-ouvertes.fr/hal-01248792
Nonlinear Unknown Input Observability: The Analytic Solution in the case of a Single Unknown Input ,
URL : https://hal.archives-ouvertes.fr/hal-01464523
Nonlinear Unknown Input Observability: The General Analytic Solution ,
A Kalman Filter-Based Algorithm for IMU-Camera Calibration: Observability Analysis and Performance Evaluation, IEEE Transactions on Robotics, vol.24, issue.5, pp.1143-1156, 2008. ,
DOI : 10.1109/TRO.2008.2004486
3D LIDAR???camera intrinsic and extrinsic calibration: Identifiability and analytical least-squares-based initialization, The International Journal of Robotics Research, vol.41, issue.4, pp.452-467, 2012. ,
DOI : 10.15607/RSS.2009.V.030
URL : http://www.cs.umn.edu/%7Estergios/papers/IJRR-2012-LidarCameraCalib.pdf
Observability analysis of a vision-aided inertial navigation system using planar features on the ground, 2013 IEEE/RSJ International Conference on Intelligent Robots and Systems, pp.4187-4194, 2013. ,
DOI : 10.1109/IROS.2013.6696956
On the linear and nonlinear observability analysis of the SLAM problem, 2009 IEEE International Conference on Mechatronics, pp.14-17, 2009. ,
DOI : 10.1109/ICMECH.2009.4957168
Observabilitybased Consistent EKF Estimators for Multi-robot Cooperative Localization, Autonomous Robots, vol.30, issue.1, pp.99-122, 2011. ,
Dorato Observing the states of systems with unmeasurable disturbance, IEEE Trans. on Aut. Control, p.20, 1975. ,
Observability analysis of SLAM using fisher information matrix, 2008 10th International Conference on Control, Automation, Robotics and Vision, 2008. ,
DOI : 10.1109/ICARCV.2008.4795699
