Abstract : We analyse various perturbations and projections of Kalman–Bucy semigroups and Riccati equations. For example, covariance inflation-type perturbations and localisation methods (projections) are common in the ensemble Kalman filtering literature. In the limit of these ensemble methods, the regularised sample covariance tends toward a solution of a perturbed/projected Riccati equation. With this motivation, results are given characterising the error between the nominal and regularised Riccati flows and Kalman–Bucy filtering distributions. New projection-type models are also discussed; e.g. Bose–Mesner projections. These regularisation models are also of interest on their own, and in, e.g., differential games, control of stochastic/jump processes, and robust control.
