Performance analysis and design of parallel kinematic machines using interval analysis - Archive ouverte HAL Access content directly
Journal Articles Mechanism and Machine Theory Year : 2017
Some design methodologies for Parallel Kinematic Machines (PKM) have been proposed but with limitations regarding two main problems: how to improve multiple properties of different nature such as accuracy, force or singularity poses, and how to check these properties for all poses inside the PKM workspace. To address these problems, this work proposes to formulate the design problem as a feasibility problem and use a data representation which takes into account the uncertainty or variation of the involved parameters. This method, based on interval analysis, allows to evaluate several performance indexes of a PKM design. For validation purposes, this methodology is applied to a PKM, obtaining a continuous set of possible kinematic parameters values for its architecture which is capable of fulfilling several performance requirements over a desired workspace.
revision2-pkm-design-2.pdf (5.66 Mo) Télécharger le fichier
Dates and versions
hal-01669173 , version 1 (20-12-2017)
Identifiers
Cite
Carlos Viegas, David Daney, Mahmoud Tavakoli, Anibal T. de Almeida. Performance analysis and design of parallel kinematic machines using interval analysis. Mechanism and Machine Theory, 2017, 115, pp.218 - 236. ⟨10.1016/j.mechmachtheory.2017.05.003⟩. ⟨hal-01669173⟩
Collections
INRIA INRIA2
126 View
383 Download
Share
