Multiple Random Walks on Paths and Grids
We derive several new results on multiple random walks on "low dimensional" graphs. First, inspired by an example of a weighted random walk on a path of three vertices given by Efremenko and Reingold, we prove the following dichotomy: as the path length n tends to infinity, we have a super-linear speed-up w.r.t. the cover time if and only if the number of walks k is equal to 2. An important ingredient of our proofs is the use of a continuous-time analogue of multiple random walks, which might be of independent interest. Finally, we also present the first tight bounds on the speed-up of the cover time for any d-dimensional grid with d >= 2 being an arbitrary constant, and reveal a sharp transition between linear and logarithmic speed-up.
