Linking focusing and resolution with selection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Focusing and selection are techniques that shrink the proof search space for respectively sequent calculi and resolution. To bring out a link between them, we generalize them both: we introduce a sequent calculus where each occurrence of an atom can have a positive or a negative polarity; and a resolution method where each literal, whatever its sign, can be selected in input clauses. We prove the equivalence between cut-free proofs in this sequent calculus and derivations of the empty clause in that resolution method. Such a generalization is not semi-complete in general, which allows us to consider complete instances that correspond to theories of any logical strength. We present three complete instances: first, our framework allows us to show that ordinary focusing corresponds to hyperresolution and semantic resolution; the second instance is deduction modulo theory and the related framework called superdeduction; and a new setting, not captured by any existing framework, extends deduction modulo theory with rewriting rules having several left-hand sides, which restricts even more the proof search space.
lipics.pdf (453.97 Ko) Télécharger le fichier
hal-01670476 , version 1 (21-12-2017)
hal-01670476 , version 2 (12-03-2018)
hal-01670476 , version 3 (27-04-2018)
Paternité
Guillaume Burel. Linking focusing and resolution with selection. 43rd International Symposium on Mathematical Foundations of Computer Science(MFCS), Aug 2018, Liverpool, United Kingdom. pp.9:1-9:14, ⟨10.4230/LIPIcs.MFCS.2018.9⟩. ⟨hal-01670476v3⟩
302 Consultations
212 Téléchargements
