Linking Focusing and Resolution with Selection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
Focusing and selection are techniques that shrink the proof search space for respectively sequent calculi and resolution. To bring out a link between them, we generalize them both: we introduce a sequent calculus where each occurrence of an atom can have a positive or a negative polarity; and a resolution method where each literal, whatever its sign, can be selected. We prove the equivalence between cut-free proofs in this sequent calculus and derivations of the empty clause in that resolution method. Such a generalization is naturally not semi-complete in general; we present three complete instances: first, our framework allows us to show that usual focusing corresponds to hyperresolution and semantic resolution; the second instance is deduction modulo theory; and a new setting extends deduction modulo theory with rewriting rules having several left-hand sides, therefore restricting even more the proof search space.
lncs.pdf (472.03 Ko) Télécharger le fichier
hal-01670476 , version 1 (21-12-2017)
hal-01670476 , version 2 (12-03-2018)
hal-01670476 , version 3 (27-04-2018)
  • HAL Id : hal-01670476 , version 1
Guillaume Burel. Linking Focusing and Resolution with Selection. 2017. ⟨hal-01670476v1⟩
302 Consultations
213 Téléchargements
