Matrix Multiplication on Two Interconnected Processors, 2006 IEEE International Conference on Cluster Computing, pp.1-9, 2006. ,
DOI : 10.1109/CLUSTR.2006.311901
URL : http://researchrepository.ucd.ie/bitstream/10197/8604/4/Becker_Lastovetsky_2006.pdf
Partitioning for Parallel Matrix-Matrix Multiplication with Heterogeneous Processors: The Optimal Solution, 2012 IEEE 26th International Parallel and Distributed Processing Symposium Workshops & PhD Forum, pp.125-139, 2012. ,
DOI : 10.1109/IPDPSW.2012.12
Towards Data Partitioning for Parallel Computing on Three Interconnected Clusters, Sixth International Symposium on Parallel and Distributed Computing (ISPDC'07), pp.39-39, 2007. ,
DOI : 10.1109/ISPDC.2007.56
URL : http://researchrepository.ucd.ie/bitstream/10197/7328/1/Becker_Lastovetsky_2007.pdf
Optimal partitioning for parallel matrix computation on a small number of abstract heterogeneous processors, p.9, 2014. ,
A New Approximation Algorithm for Matrix Partitioning in Presence of Strongly Heterogeneous Processors, 2016 IEEE International Parallel and Distributed Processing Symposium (IPDPS), 2016. ,
DOI : 10.1109/IPDPS.2016.32
URL : https://hal.archives-ouvertes.fr/hal-01216245
An approximation algorithm for dissecting a rectangle into rectangles with specified areas, Discrete Applied Mathematics, vol.155, issue.4, pp.523-537, 2007. ,
DOI : 10.1016/j.dam.2006.08.005
Exact and approximation algorithms for a soft rectangle packing problem, Optimization, vol.63, issue.11, pp.1637-1663, 2014. ,
DOI : 10.1109/43.920707
Heterogeneous Distribution of Computations Solving Linear Algebra Problems on Networks of Heterogeneous Computers, Journal of Parallel and Distributed Computing, vol.61, issue.4, pp.520-535, 2001. ,
DOI : 10.1006/jpdc.2000.1686
Partitioning a Square into Rectangles: NP-Completeness and Approximation Algorithms, Algorithmica, vol.34, issue.3, pp.217-239, 2002. ,
DOI : 10.1007/s00453-002-0962-9
URL : https://hal.archives-ouvertes.fr/hal-00807407
High-level data partitioning for parallel computing on heterogeneous hierarchical computational platforms, 2010. ,
Max-Plus Algebra and Discrete Event Simulation on Parallel Hierarchical Heterogeneous Platforms, Euro- Par 2010 Parallel Processing Workshops, pp.63-70, 2011. ,
DOI : 10.1002/9780470508206
URL : https://hal.archives-ouvertes.fr/hal-00690368
Searching for the Optimal Data Partitioning Shape for Parallel Matrix Matrix Multiplication on 3 Heterogeneous Processors, 2014 IEEE International Parallel & Distributed Processing Symposium Workshops, pp.17-28, 2014. ,
DOI : 10.1109/IPDPSW.2014.8
Static LU Decomposition on Heterogeneous Platforms, The International Journal of High Performance Computing Applications, vol.15, issue.3, 2001. ,
DOI : 10.1007/BFb0100580
URL : https://hal.archives-ouvertes.fr/hal-00789435
A proposal for a heterogeneous cluster ScaLAPACK (dense linear solvers), IEEE Transactions on Computers, vol.50, issue.10, pp.1052-1070, 2001. ,
DOI : 10.1109/12.956091
URL : https://hal.archives-ouvertes.fr/hal-00808287
ScaLAPACK users' guide. Siam, 1997. ,
DOI : 10.1137/1.9780898719642
Hierarchical Partitioning Algorithm for Scientific Computing on Highly Heterogeneous CPU + GPU Clusters, European Conference on Parallel Processing, pp.489-501, 2012. ,
DOI : 10.1007/978-3-642-32820-6_49
On optimization of finite-difference time-domain (FDTD) computation on heterogeneous and GPU clusters, Journal of Parallel and Distributed Computing, vol.71, issue.4, pp.584-593, 2011. ,
DOI : 10.1016/j.jpdc.2010.10.011
DDOps: dual-direction operations for load balancing on non-dedicated heterogeneous distributed systems, Cluster Computing, vol.16, issue.1, pp.503-528, 2014. ,
DOI : 10.1007/s10586-011-0171-x
StarPU: a unified platform for task scheduling on heterogeneous multicore architectures, Concurrency and Computation: Practice and Experience, pp.187-198, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00384363
Hierarchical Task-Based Programming With StarSs, The International Journal of High Performance Computing Applications, vol.17, issue.1, pp.284-299, 2009. ,
DOI : 10.1109/5.476078
QUARK users' guide: Queueing and runtime for kernels, 2011. ,
PaRSEC: Exploiting Heterogeneity to Enhance Scalability, Computing in Science & Engineering, vol.15, issue.6, pp.36-45, 2013. ,
DOI : 10.1109/MCSE.2013.98
Comparison of static and dynamic resource allocation strategies for matrix multiplication Minimizing communication in linear algebra, 26th IEEE International Symposium on Computer Architecture and High Performance Computing, pp.866-901, 2011. ,
On the Effect of Replication of Input Files on the Efficiency and the Robustness of a Set of Computations ,
URL : https://hal.archives-ouvertes.fr/tel-01661588
