Constrained L2-approximation by polynomials on subsets of the circle - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2018
We study best approximation to a given function, in the least square sense on a subset of the unit circle, by polynomials of given degree which are pointwise bounded on the complementary subset. We show that the solution to this problem, as the degree goes large, converges to the solution of a bounded extremal problem for analytic functions which is instrumental in system identification. We provide a numerical example on real data from a hyperfrequency filter.
BLSFields2017.pdf (336.23 Ko) Télécharger le fichier
hal-01671183 , version 2 (29-10-2017)
hal-01671183 , version 1 (22-12-2017)
Laurent Baratchart, Juliette Leblond, Fabien Seyfert. Constrained L2-approximation by polynomials on subsets of the circle. Mashreghi, Javad; Manolaki, Myrto; Gauthier, Paul M. New Trends in Approximation Theory. In Memory of André Boivin, 81, Springer, pp.151-171, 2018, Fields Institute Communications, 978-1-4939-7543-3. ⟨10.1007/978-1-4939-7543-3_8⟩. ⟨hal-01671183v2⟩
Collections
INRIA INRIA2
401 Consultations
747 Téléchargements
