MARTE for CPS and CPSoS: Present and Future, Methodology and Tools - Archive ouverte HAL Access content directly
Book Sections Year : 2017
Cyber-Physical Systems (CPS) combine discrete computing elements together with physical devices in uncertain environment conditions. There have been many models to capture different aspects of CPS. However, to deal with the increasing complexity of these ubiquitous systems, which invade all the part of our lives, we need an integrated framework able to capture all the different views of such complex systems in a consistent way. We also need to combine tools to analyze their expected properties and guarantee safety issues. Far from handing out a full-fledge solution, we merely explore a possible path that could bring part of the solution. We advocate for relying on uml models as a unifying framework to build a single-source modeling environment with design, exploration and analysis tools. We comment on some useful extensions of UML, including MARTE and SysML, and show how they can together capture different views of CPS. We also report on some recent results obtained and discuss possible evolutions in a near future.
main_public.pdf (2.4 Mo) Télécharger le fichier
Dates and versions
hal-01671190 , version 1 (08-01-2018)
Identifiers
Cite
Frédéric Mallet, Eugenio Villar, Fernando Herrera. MARTE for CPS and CPSoS: Present and Future, Methodology and Tools. Jean-Pierre Talpin. Cyber-Physical System Design from an Architecture Analysis Viewpoint, Springer, pp.81-108, 2017, 978-981-10-4435-9. ⟨10.1007/978-981-10-4436-6_4⟩. ⟨hal-01671190⟩
418 View
384 Download
Share
