Detectability and Stabilizability of Time-Varying Discrete-Time Linear Systems, SIAM Journal on Control and Optimization, vol.19, issue.1, pp.20-32, 1981. ,
DOI : 10.1137/0319002
On observer problems for systems governed by partial differential equations, 1987. ,
DOI : 10.21236/ADA187430
Dynamic Observers as Asymptotic Limits of Recursive Filters: Special Cases, SIAM Journal on Applied Mathematics, vol.48, issue.5, pp.1147-1158, 1988. ,
DOI : 10.1137/0148068
Nonlinear Filtering: The Set-Membership (Bounding) and the H Techniques, 1995. ,
DOI : 10.1016/b978-0-08-042371-5.50072-1
Dynamic Programming, 1957. ,
Filtrage optimal des systèmes linéaires. Dunod, 1971. ,
Stochastic control of partially observable systems, 1992. ,
DOI : 10.1017/CBO9780511526503
Representation and control of infinite-dimensional systems, II. Systems & Control: Foundations & Applications, 1993. ,
DOI : 10.1007/978-0-8176-4581-6
Data assimilation for geophysical fluids. Computational Methods for the Atmosphere and the Oceans, pp.385-441, 2009. ,
DOI : 10.1016/s1570-8659(08)00209-3
URL : https://hal.archives-ouvertes.fr/inria-00391892
An Adaptive Sparse Grid Semi-Lagrangian Scheme for First Order Hamilton-Jacobi Bellman Equations, Journal of Scientific Computing, vol.24, issue.7, pp.575-605, 2013. ,
DOI : 10.1137/S1064827501396798
URL : https://hal.archives-ouvertes.fr/hal-00741178
Existence theorems for weak and usual optimal solutions in Lagrange problems with unilateral constraints. II. Existence theorems for weak solutions, Transactions of the American Mathematical Society, vol.124, issue.3, pp.413-430, 1966. ,
DOI : 10.1090/S0002-9947-1966-0203543-3
Fundamental principles of data assimilation underlying the Verdandi library: applications to biophysical model personalization within euHeart, Medical & Biological Engineering & Computing, vol.4, issue.7, pp.511221-1233, 2012. ,
DOI : 10.1016/j.jmbbm.2011.03.018
URL : https://hal.archives-ouvertes.fr/hal-00760887
A Galerkin strategy with Proper Orthogonal Decomposition for parameter-dependent problems ??? Analysis, assessments and applications to parameter estimation, ESAIM: Mathematical Modelling and Numerical Analysis, vol.47, issue.6, 2013. ,
DOI : 10.1002/fld.867
URL : https://hal.archives-ouvertes.fr/hal-00834397
Nonlinear Least Squares for Inverse Problems, 2010. ,
DOI : 10.1007/978-90-481-2785-6
Bayesian filtering: From Kalman filters to particle filters, and beyond, Statistics, vol.182, issue.1, pp.1-69, 2003. ,
Data assimilation of time under-sampled measurements using observers, the wave-like equation example, ESAIM Control Optim. Calc. Var, vol.21, issue.3, pp.635-669, 2015. ,
On the estimation of state variables and parameters for noisy dynamic systems, IEEE Transactions on Automatic Control, vol.9, issue.1, 1964. ,
DOI : 10.1109/TAC.1964.1105635
Discrete approximations in optimal control In Nonsmooth analysis and geometric methods in deterministic optimal control, pp.59-80, 1996. ,
Deterministic nonlinear filtering, Ann. Scuola Norm. Sup. Pisa Cl. Sci, vol.25, issue.43-4, pp.435-454, 1997. ,
A Max-Plus-Based Algorithm for a Hamilton--Jacobi--Bellman Equation of Nonlinear Filtering, SIAM Journal on Control and Optimization, vol.38, issue.3, pp.683-710, 2000. ,
DOI : 10.1137/S0363012998332433
Deterministic and Stochastic Optimal Control, 1975. ,
DOI : 10.1007/978-1-4612-6380-7
Asymptotic nonlinear filtering and large deviations Advances in Filtering and Optimal Stochastic Control, pp.170-176, 1982. ,
DOI : 10.1007/bfb0004536
Nonlinear filtering and large deviations, 26th IEEE Conference on Decision and Control, pp.391-412, 1988. ,
DOI : 10.1109/CDC.1987.272708
URL : http://www.hynet.umd.edu/%7Ebaras////publications/papers/1987/1987_James_Nonlinear_Filtering.pdf
New extension of the Kalman filter to nonlinear systems, Signal Processing, Sensor Fusion, and Target Recognition VI, pp.182-193, 1997. ,
DOI : 10.1117/12.280797
Contributions to the theory of optimal control, Bol. Soc. Mat. Mexicana, vol.5, issue.2, pp.102-119, 1960. ,
A New Approach to Linear Filtering and Prediction Problems, Journal of Basic Engineering, vol.82, issue.1, pp.35-45, 1960. ,
DOI : 10.1115/1.3662552
Mathematical Description of Linear Dynamical Systems, Journal of the Society for Industrial and Applied Mathematics Series A Control, vol.1, issue.2, pp.152-192, 1963. ,
DOI : 10.1137/0301010
New Results in Linear Filtering and Prediction Theory, Journal of Basic Engineering, vol.83, issue.1, pp.95-108, 1961. ,
DOI : 10.1115/1.3658902
URL : http://www.eecs.tufts.edu/~khan/Courses/Spring2012/EE194/Lecs/KalmanBucy1961.pdf
A Lyapunov Theory of Nonlinear Observers, Stochastic analysis, control, optimization and applications, pp.409-420, 1998. ,
DOI : 10.1007/978-1-4612-1784-8_24
The Convergence of the Minimum Energy Estimator, New trends in nonlinear dynamics and control, and their applications, pp.187-208, 2003. ,
DOI : 10.1007/978-3-540-45056-6_12
A hybrid computational approach to nonlinear estimation, Proceedings of 35th IEEE Conference on Decision and Control, pp.1815-1819, 1996. ,
DOI : 10.1109/CDC.1996.572831
HJB-POD-Based Feedback Design for the Optimal Control of Evolution Problems, SIAM Journal on Applied Dynamical Systems, vol.3, issue.4, pp.701-722, 2004. ,
DOI : 10.1137/030600485
Dynamical equations for optimal nonlinear filtering, Journal of Differential Equations, vol.3, issue.2, pp.179-190, 1967. ,
DOI : 10.1016/0022-0396(67)90023-X
URL : https://doi.org/10.1016/0022-0396(67)90023-x
Variational algorithms for analysis and assimilation of meteorological observations: theoretical aspects, Tellus A, vol.109, issue.2, pp.97-110, 2010. ,
DOI : 10.1007/978-3-642-65024-6
Reduced-order Unscented Kalman Filtering with application to parameter identification in large-dimensional systems, ESAIM: Control, Optimisation and Calculus of Variations, vol.14, issue.2, pp.380-405, 2011. ,
DOI : 10.1002/stc.186
URL : https://hal.archives-ouvertes.fr/inria-00550104
Maximum-likelihood recursive nonlinear filtering, Journal of Optimization Theory and Applications, vol.2, issue.6, pp.386-394, 1968. ,
DOI : 10.1007/BF00925744
Data Assimilation for Numerical Weather Prediction: A Review, Data Assimilation for Atmospheric, Oceanic and Hydrologic Applications, 2009. ,
DOI : 10.1007/978-3-540-71056-1_2
Nonlinear dynamic systems and optimal control problems on time scales, ESAIM: Control, Optimisation and Calculus of Variations, vol.49, issue.3, pp.654-681, 2010. ,
DOI : 10.1016/j.mcm.2008.12.008
URL : http://www.esaim-cocv.org/articles/cocv/pdf/2011/03/cocv0978.pdf
A singular evolutive extended Kalman filter for data assimilation in oceanography, Journal of Marine systems, vol.16, pp.3-4323, 1998. ,
Optimal State Estimation: Kalman, H ? , and Nonlinear Approaches, 2006. ,
DOI : 10.1002/0470045345
Nonlinear Systems Analysis, 1993. ,
