New interface
Conference papers
Typed Template Coq -- Certified Meta-Programming in Coq
Abhishek Anand 1 Simon Boulier 2 Nicolas Tabareau 2, 3 Matthieu Sozeau 4
2 LS2N - équipe GALLINETTE - Gallinette : vers une nouvelle génération d'assistant à la preuve
Inria Rennes – Bretagne Atlantique , LS2N - Laboratoire des Sciences du Numérique de Nantes
4 PI.R2 - Design, study and implementation of languages for proofs and programs
UPD7 - Université Paris Diderot - Paris 7, CNRS - Centre National de la Recherche Scientifique, IRIF (UMR_8243) - Institut de Recherche en Informatique Fondamentale, Inria de Paris
Abstract : Template-Coq is a plugin for Coq, originally implemented by Malecha, which provides a reifier for Coq terms and global declarations , as represented in the Coq kernel, as well as a denotation command. Initially, it was developed for the purpose of writing functions on Coq's AST in Gallina. Recently, its use was extended for the needs of the CertiCoq certified compiler project, which uses it as its front-end language and to derive parametricity properties, and the work of Forster on extracting Coq terms to a CBV λ-calculus. However, the syntax currently lacks semantics, be it typing semantics or operational semantics, which should reflect, as formal specifications in Coq, the semantics of Coq itself. This is an issue for CertiCoq where both a non-deterministic small step semantics and a deterministic call-by-value big step semantics had to be defined and preserved, without an " official " reference specification to refer to. Our hope with this work is to remedy this situation and provide a formal semantics of Coq's implemented type theory, that can independently be refined and studied. By implementing a (partial) independent checker in Coq, we can also help formalize certified translations from Coq to Coq.
Document type :
Conference papers
Complete list of metadata
Cited literature [9 references]  Display  Hide  Download
https://hal.inria.fr/hal-01671948
Contributor : Matthieu Sozeau Connect in order to contact the contributor
Submitted on : Friday, December 22, 2017 - 5:42:56 PM
Last modification on : Thursday, December 1, 2022 - 11:00:07 AM
File
Anand-Boulier-Tabareau-Sozeau-...
Identifiers
  • HAL Id : hal-01671948, version 1
Citation
Abhishek Anand, Simon Boulier, Nicolas Tabareau, Matthieu Sozeau. Typed Template Coq -- Certified Meta-Programming in Coq. CoqPL 2018 - The Fourth International Workshop on Coq for Programming Languages, Jan 2018, Los Angeles, CA, United States. pp.1-2. ⟨hal-01671948⟩
Share
Metrics
Record views
946
Files downloads
251
