On k-anonymity and the curse of dimensionality, Proceedings of the 31st VLDB Conference, 2005. ,
k-means++: The advantages of careful seeding, Proceedings of the eighteenth annual ACM-SIAM symposium on Discrete algorithms, 2007. ,
Proximal Alternating Minimization and Projection Methods for Nonconvex Problems: An Approach Based on the Kurdyka-??ojasiewicz Inequality, Mathematics of Operations Research, vol.35, issue.2, 2010. ,
DOI : 10.1287/moor.1100.0449
Sharp analysis of low-rank kernel matrix approximations, International Conference on Learning Theory (COLT), 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00723365
Diffrac: a discriminative and flexible framework for clustering, Advances in Neural Information Processing Systems, pp.49-56, 2008. ,
Convex Analysis and Monotone Operator Theory in Hilbert Spaces, 2011. ,
DOI : 10.1007/978-3-319-48311-5
URL : https://hal.archives-ouvertes.fr/hal-00643354
A Fast Iterative Shrinkage-Thresholding Algorithm for Linear Inverse Problems, SIAM Journal on Imaging Sciences, vol.2, issue.1, pp.183-202, 2009. ,
DOI : 10.1137/080716542
URL : http://ie.technion.ac.il/%7Ebecka/papers/finalicassp2009.pdf
Proximal alternating linearized minimization for nonconvex and nonsmooth problems, Mathematical Programming, pp.459-494, 2014. ,
DOI : 10.1007/BF01584660
URL : https://hal.archives-ouvertes.fr/hal-00916090
Convergence properties of the k-means algorithms, Advances in Neural Information Processing Systems 7, pp.585-592, 1995. ,
PECOK: A convex optimization approach to variable clustering, p.2016 ,
The restricted isometry property and its implications for compressed sensing, Comptes Rendus Mathematique, vol.346, issue.9-10, pp.589-592, 2008. ,
DOI : 10.1016/j.crma.2008.03.014
Enhancing sparsity by reweighted ?1 minimization, Journal of Fourier analysis and applications, vol.14, pp.5-6877, 2008. ,
On the convergence of the iterates of "fista, Journal of Optimization Theory and Applications, issue.166, p.2015 ,
URL : https://hal.archives-ouvertes.fr/hal-01060130
Proximal splitting methods in signal processing In Fixed-point algorithms for inverse problems in science and engineering, pp.185-212, 2011. ,
Signal Recovery by Proximal Forward-Backward Splitting, Multiscale Modeling & Simulation, vol.4, issue.4, pp.1168-1200, 2005. ,
DOI : 10.1137/050626090
URL : https://hal.archives-ouvertes.fr/hal-00017649
Fast projection onto the simplex and the $$\pmb {l}_\mathbf {1}$$ l 1 ball, Mathematical Programming, vol.31, issue.3, pp.575-585, 2016. ,
DOI : 10.1137/080714488
A convex approach to k-means clustering and image segmentation, p.2017 ,
URL : https://hal.archives-ouvertes.fr/hal-01504799
Discriminative cluster analysis, Proceedings of the 23rd international conference on Machine learning , ICML '06, 2006. ,
DOI : 10.1145/1143844.1143875
-means clustering, Proceedings of the 24th international conference on Machine learning, ICML '07, pp.521-528, 2007. ,
DOI : 10.1145/1273496.1273562
Optimally sparse representation in general (nonorthogonal) dictionaries via ?1 minimization, Proceedings of the National Academy of Sciences, pp.2197-2202, 2003. ,
DOI : 10.1073/pnas.0437847100
URL : http://www.pnas.org/content/100/5/2197.full.pdf
Signal Recovery and the Large Sieve, SIAM Journal on Applied Mathematics, vol.52, issue.2, pp.577-591, 1992. ,
DOI : 10.1137/0152031
Efficient projections onto the l 1-ball for learning in high dimensions, Proceedings of the 25th international conference on Machine learning, pp.272-279, 2008. ,
Robust discriminative clustering with sparse regularizers, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01357666
The entire regularization path for the support vector machine, Journal of Machine Learning Research, vol.5, pp.1391-1415, 2004. ,
Laplacian score for feature selection, Advances in Neural Information Processing Systems 18, pp.507-514, 2006. ,
Comparing partitions, Journal of Classification, 1985. ,
Splitting Algorithms for the Sum of Two Nonlinear Operators, SIAM Journal on Numerical Analysis, vol.16, issue.6, pp.964-979, 1979. ,
DOI : 10.1137/0716071
Complexity analysis of the lasso regularization path, Proceedings of the 29th International Conference on Machine Learning (ICML-12), pp.353-360, 2012. ,
Clustering subgaussian mixtures with k-means. Information and inference, pp.1-27, 2017. ,
DOI : 10.1109/itw.2016.7606826
Solving Structured Sparsity Regularization with Proximal Methods, Machine Learning and Knowledge Discovery in Databases, pp.418-433 ,
DOI : 10.1007/978-3-642-15883-4_27
URL : http://lcsl.mit.edu/papers/prox_ECML.pdf
On spectral clustering: Analysis and an algorithm, Advances in Neural Information Processing Systems 14, pp.849-856, 2002. ,
Approximating K???means???type Clustering via Semidefinite Programming, SIAM Journal on Optimization, vol.18, issue.1, pp.186-205, 2017. ,
DOI : 10.1137/050641983
URL : http://www.cas.mcmaster.ca/~oplab/publication/report/2005-5.pdf
Hubs in space : Popular nearest neighbors in high-dimensional data, Journal of Machine Learning Research, vol.11, pp.2487-2531 ,
K-Means-Type Algorithms: A Generalized Convergence Theorem and Characterization of Local Optimality, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.6, issue.1, pp.81-87, 1984. ,
DOI : 10.1109/TPAMI.1984.4767478
Optimization for Machine Learning, 2012. ,
Regression shrinkage and selection via the lasso, Journal of the Royal Statistical Society. Series B (Methodological), pp.267-288, 1996. ,
DOI : 10.1111/j.1467-9868.2011.00771.x
Estimating the number of clusters in a data set via the gap statistic, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.63, issue.2, pp.411-423, 2001. ,
DOI : 10.1111/1467-9868.00293
Visualizing high-dimensional data using t-sne, Journal of Machine Learning Research, vol.9, pp.2579-2605, 2008. ,
A tutorial on spectral clustering, Statistics and Computing, vol.21, issue.1, 2007. ,
DOI : 10.1017/CBO9780511810633
Visualization and analysis of single-cell rna-seq data by kernel-based similarity learning, Nature methods, issue.14, p.2017 ,
On using principal components before separating a mixture of two multivariate normal distributions, Journal of the Royal Statistical Society, vol.32, issue.3, 1983. ,
A Framework for Feature Selection in Clustering, Journal of the American Statistical Association, vol.105, issue.490, pp.713-726, 2010. ,
DOI : 10.1198/jasa.2010.tm09415
