Embedded Bayesian Perception by Dynamic Occupancy Grid Filtering
A generic Bayesian perception framework, designed to estimate a dense representation of dynamic environments, by fusing and filtering multi-sensor data, has been developed, implemented and tested on embedded devices. The main features of the approach are the followings:
• Data from multiple sensors are properly fused in probabilistic occupancy grids.
• Motion and robust occupancy are estimated by a specific Bayesian filter.
• Short-term collision risks and object parameters are assessed.
• The whole system has been implemented and tested on Nvidia embedded devices, and produces real-time results.
