Dose- and time-dependence of the host-mediated response to paclitaxel therapy: a mathematical modeling approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Oncotarget Année : 2017
It has recently been suggested that pro-tumorigenic host-mediated processes induced in response to chemotherapy counteract the anti-tumor activity of therapy, and thereby decrease net therapeutic outcome. Here we use experimental data to formulate a mathematical model describing the host response to different doses of paclitaxel (PTX) chemotherapy as well as the duration of the response. Three previously described host-mediated effects are used as readouts for the host response to therapy. These include the levels of circulating endothelial progenitor cells in peripheral blood and the effect of plasma derived from PTX-treated mice on migratory and invasive properties of tumor cells in vitro. A first set of mathematical models, based on basic principles of pharmacokinetics/pharmacodynamics, did not appropriately describe the dose-dependence and duration of the host response regarding the effects on invasion. We therefore provide an alternative mathematical model with a dose-dependent threshold, instead of a concentration-dependent one, that describes better the data. This model is integrated into a global model defining all three host-mediated effects. It not only precisely describes the data, but also correctly predicts host-mediated effects at different doses as well as the duration of the host response. This mathematical model may serve as a tool to predict the host response to chemotherapy in cancer patients, and therefore may be used to design chemotherapy regimens with improved therapeutic outcome by minimizing host mediated effects.
Cancer
Benguigui_2017_O_Dose and time dependence of the host-mediated response to paclitaxel therapy a mathematical modeling approach (1).pdf (5.71 Mo) Télécharger le fichier
hal-01672568 , version 1 (26-12-2017)
Madeleine Benguigui, Dror Alishekevitz, Michael Timaner, Dvir Shechter, Ziv Raviv, et al.. Dose- and time-dependence of the host-mediated response to paclitaxel therapy: a mathematical modeling approach. Oncotarget, 2017, 9 (2), pp.2574-2590. ⟨10.18632/oncotarget.23514⟩. ⟨hal-01672568⟩
142 Consultations
25 Téléchargements
