Journal articles
Objective measurement of gait parameters in healthy and cognitively impaired elderly using the dual-task paradigm
Abstract : Objectives The present study explores the differences in gait parameters in elderly subjects with or without cognitive impairment measured by means of ambulatory actigraphy while performing a single and a dual task. Methods Sixty-nine participants of which 23 individuals were diagnosed with Alzheimer’s disease (AD), 24 with mild cognitive impairment (MCI), and 22 healthy controls performed a single and dual walking task while wearing a wrist-worn accelerometer. Objective measures of gait features such as walking speed, cadence (i.e., number of steps per minute), and step variance (i.e., variance in time between two consecutive steps) were derived and analyzed. Results While differences in several gait parameters, namely walking speed, were found between MCI and AD patients, no differences between healthy elderly and MCI patients were found. Conclusion Walking speed seems to be a gait-related feature that differs significantly between MCI and AD patients and thus could be used as an additional measurement in clinical assessment. However, differences in gait may not be salient enough in the early stages of dementia to be detected by actigraphy. More research comparing different methods to measure gait in early stages of dementia under different dual task conditions is necessary.
Document type :
Journal articles
Complete list of metadata
Cited literature [37 references]  Display  Hide  Download
https://hal.inria.fr/hal-01672597
Contributor : Annie Ressouche Connect in order to contact the contributor
Submitted on : Tuesday, December 26, 2017 - 12:54:13 PM
Last modification on : Saturday, June 25, 2022 - 11:28:48 PM
Long-term archiving on: : Tuesday, March 27, 2018 - 12:25:23 PM
File
objective_measurement.pdf
Identifiers
Collections
Citation
Alexandra Konig, Laura Klaming, Marten Pijl, Alexandre Demeurraux, Renaud David, et al.. Objective measurement of gait parameters in healthy and cognitively impaired elderly using the dual-task paradigm. Aging Clinical and Experimental Research, Springer Verlag, 2017, 29 (6), pp.1181 - 1189. ⟨10.1007/s40520-016-0703-6⟩. ⟨hal-01672597⟩
Share
Metrics
Record views
71
Files downloads
89
