HYPERBOLICITY NOTIONS FOR VARIETIES DEFINED OVER A NON-ARCHIMEDEAN FIELD
Firstly, we pursue the work of W. Cherry on the analogue of the Kobayashi semi distance dCK that he introduced for analytic spaces defined over a non-Archimedean metrized field k. We prove various characterizations of smooth projective varieties for which dCK is an actual distance. Secondly, we explore several notions of hyperbolicity for a smooth algebraic curve X defined over k. We prove a non-Archimedean analogue of the equivalence between having negative Euler characteristic and the normality of certain families of analytic maps taking values in X.
Géométrie algébrique [math.AG]
