Processing of Grammatical Gender in Normal and Aphasic Speakers of Russian, Cortex, vol.37, issue.3, pp.295-326, 2001. ,
DOI : 10.1016/S0010-9452(08)70576-8
The two-stage model of lexical retrieval: evidence from a case of anomia with selective preservation of grammatical gender, Cognition, vol.57, issue.2, pp.193-216, 1995. ,
DOI : 10.1016/0010-0277(95)00663-J
Neural Correlates of Lexical Access during Visual Word Recognition, Journal of Cognitive Neuroscience, vol.2, issue.3, pp.372-93, 2003. ,
DOI : 10.3758/BF03198326
URL : http://miwalab.cog.human.nagoya-u.ac.jp/database/paper/2011-11-17.pdf
The representation of lexical-syntactic information: Evidence from syntactic and lexical retrieval impairments in aphasia, Cortex, vol.48, issue.9, pp.1103-1130, 2012. ,
DOI : 10.1016/j.cortex.2011.05.024
How Many Levels of Processing Are There in Lexical Access?, Cognitive Neuropsychology, vol.14, issue.1, pp.177-208, 1997. ,
DOI : 10.1080/026432997381664
The relation between syntactic and phonological knowledge in lexical access: evidence from the `tip-of-the-tongue' phenomenon, Cognition, vol.64, issue.3, pp.309-352, 1997. ,
DOI : 10.1016/S0010-0277(97)00031-0
Evocation lexicale formelle et sémantique chez des sujets normaux. Performances et dynamiques de la production en fonction du sexe, de l'âge et du niveau d'étude, Acta Neurologica Belgica, vol.90, pp.207-224, 1990. ,
Anatomy of Stroke, Part I: An MRI-Based Topographic and Volumetric System of Analysis, Stroke, vol.33, issue.11, pp.2549-56, 2002. ,
DOI : 10.1161/01.STR.0000036083.90045.08
Computational modelling of the effects of semantic dementia on visual word recognition, Cognitive Neuropsychology, vol.117, issue.2, pp.101-115, 2010. ,
DOI : 10.1037/a0017641
Test de dénomination orale d'images : DO 80, 1997. ,
The FAB: A frontal assessment battery at bedside, Neurology, vol.55, issue.11, pp.1621-1626, 2000. ,
DOI : 10.1212/WNL.55.11.1621
The production of pronominal clitics: Implications for theories of lexical access, Language and Cognitive Processes, vol.82, issue.1-3, pp.141-80, 2006. ,
DOI : 10.1016/S0010-0277(02)00103-8
Measuring the thickness of the human cerebral cortex from magnetic resonance images, Proceedings of the National Academy of Sciences, vol.2, issue.2, pp.11050-55, 2000. ,
DOI : 10.4310/jdg/1214444092
???Mini-mental state???, Journal of Psychiatric Research, vol.12, issue.3, pp.189-198, 1975. ,
DOI : 10.1016/0022-3956(75)90026-6
The Role of Left Inferior Frontal and Superior Temporal Cortex in Sentence Comprehension: Localizing Syntactic and Semantic Processes, Cerebral Cortex, vol.13, issue.2, pp.70-77, 2003. ,
DOI : 10.1093/cercor/13.2.170
A Parametric Manipulation of Central Executive Functioning, Cerebral Cortex, vol.10, issue.6, pp.585-92, 2000. ,
DOI : 10.1093/cercor/10.6.585
The logopenic/phonological variant of primary progressive aphasia, Neurology, vol.71, issue.16, pp.1227-1261, 2008. ,
DOI : 10.1212/01.wnl.0000320506.79811.da
Cognition and anatomy in three variants of primary progressive aphasia, Annals of Neurology, vol.60, issue.3, pp.335-381, 2004. ,
DOI : 10.1212/01.WNL.0000044340.37138.A9
Classification of primary progressive aphasia and its variants, Neurology, vol.76, issue.11, pp.1006-1020, 2011. ,
DOI : 10.1212/WNL.0b013e31821103e6
Neural Systems for Reading Aloud: A Multiparametric Approach, Cerebral Cortex, vol.20, issue.8, pp.1799-1815, 2010. ,
DOI : 10.1093/cercor/bhp245
URL : https://academic.oup.com/cercor/article-pdf/20/8/1799/17303249/bhp245.pdf
The Left Posterior Superior Temporal Gyrus Participates Specifically in Accessing Lexical Phonology, Journal of Cognitive Neuroscience, vol.10, issue.537, pp.1698-1710, 2008. ,
DOI : 10.1097/00004728-199801000-00028
Lexicalization in an anomic patient, Neuropsychologia, vol.27, issue.4, pp.391-407, 1989. ,
DOI : 10.1016/0028-3932(89)90047-X
Foundations of Language, 2002. ,
DOI : 10.1093/acprof:oso/9780198270126.001.0001
Sensitivity to gender, person, and tense inflection by persons with Alzheimer???s disease, Brain and Language, vol.87, issue.2, pp.267-77, 2003. ,
DOI : 10.1016/S0093-934X(03)00106-8
Task and semantic relationship influence both the polarity and localization of hemodynamic modulation during lexico-semantic processing, Human Brain Mapping, vol.10, issue.5, pp.544-61, 2008. ,
DOI : 10.3758/BF03196557
Automatic Semantic Facilitation in Anterior Temporal Cortex Revealed through Multimodal Neuroimaging, Journal of Neuroscience, vol.33, issue.43, pp.17174-81, 2013. ,
DOI : 10.1523/JNEUROSCI.1018-13.2013
URL : http://www.jneurosci.org/content/jneuro/33/43/17174.full.pdf
Accessing words in speech production: Stages, processes and representations, Cognition, vol.42, issue.1-3, pp.1-22, 1992. ,
DOI : 10.1016/0010-0277(92)90038-J
URL : http://pubman.mpdl.mpg.de/pubman/item/escidoc:196875:5/component/escidoc:521898/Levelt_Accessing_Words_1993.pdf
The neural basis of logopenic progressive aphasia, Journal of Alzheimer's Disease, vol.32, pp.1051-1059, 2012. ,
Cognitive decline in logopenic aphasia: More than losing words, Neurology, vol.80, issue.10, pp.897-903, 2013. ,
DOI : 10.1212/WNL.0b013e318285c15b
Boston Diagnostic Aphasia Examination, 1982. ,
Words and objects at the tip of the left temporal lobe in primary progressive aphasia, Brain, vol.136, issue.2, pp.601-619, 2013. ,
DOI : 10.1093/brain/aws336
The Brain Network of Naming: A Lesson from Primary Progressive Aphasia, PLOS ONE, vol.8, issue.11, p.148707, 2016. ,
DOI : 10.1371/journal.pone.0148707.s001
URL : https://hal.archives-ouvertes.fr/hal-01294408
Semantic priming and retrieval from lexical memory: Evidence for facilitatory and inhibitory processes, Memory & Cognition, vol.4, issue.5, pp.648-654, 1976. ,
DOI : 10.3758/BF03213230
URL : https://link.springer.com/content/pdf/10.3758%2FBF03213230.pdf
Une base de donn??es lexicales du fran??ais contemporain sur internet : LEXIQUE???//A lexical database for contemporary french : LEXIQUE???, L'ann??e psychologique, vol.101, issue.3, pp.447-62, 2004. ,
DOI : 10.3406/psy.2001.1341
URL : http://www.persee.fr/docAsPDF/psy_0003-5033_2001_num_101_3_1341.pdf
Things, Words and the Brain*, Quarterly Journal of Experimental Psychology, vol.24, issue.4, pp.340-53, 1996. ,
DOI : 10.1038/206218a0
Cortical representation of the constituent structure of sentences, Proceedings of the National Academy of Sciences, vol.22, issue.7, pp.2522-2529, 2011. ,
DOI : 10.1162/jocn.2009.21283
Multiple dimensions of relatedness among words: Conjoint effects of form and meaning in word recognition, The Mental Lexicon, vol.4, issue.1, pp.1-25, 2009. ,
DOI : 10.1075/ml.4.1.01pas
Cerebral localization of impaired phonological retrieval during rhyme judgment, Annals of Neurology, vol.33, issue.5, pp.738-784, 2014. ,
DOI : 10.1016/j.neuroimage.2006.06.054
URL : https://www.ncbi.nlm.nih.gov/pmc/articles/PMC4214892/pdf
An area essential for linking word meanings to word forms: Evidence from primary progressive aphasia, Brain and Language, vol.127, issue.2, pp.167-76, 2013. ,
DOI : 10.1016/j.bandl.2013.09.004
URL : https://www.ncbi.nlm.nih.gov/pmc/articles/PMC3906671/pdf
Anatomy of Language Impairments in Primary Progressive Aphasia, Journal of Neuroscience, vol.31, issue.9, pp.3344-50, 2011. ,
DOI : 10.1523/JNEUROSCI.5544-10.2011
NATURAL SELECTION: THE IMPACT OF SEMANTIC IMPAIRMENT ON LEXICAL AND OBJECT DECISION, Cognitive Neuropsychology, vol.2, issue.2-4, pp.331-352, 2004. ,
DOI : 10.1080/14640747508400525
Recruitment of anterior and posterior structures in lexical???semantic processing: An fMRI study comparing implicit and explicit tasks, Brain and Language, vol.105, issue.1, pp.41-49, 2008. ,
DOI : 10.1016/j.bandl.2008.01.003
Converging Language Streams in the Human Temporal Lobe, Journal of Neuroscience, vol.26, issue.28, pp.7328-7364, 2006. ,
DOI : 10.1523/JNEUROSCI.0559-06.2006
Left inferior frontal cortex and syntax: function, structure and behaviour in patients with left hemisphere damage, Brain, vol.134, issue.2, pp.415-446, 2011. ,
DOI : 10.1093/brain/awq369
URL : https://academic.oup.com/brain/article-pdf/134/2/415/17346925/awq369.pdf
Words with and without internal structure: What determines the nature of orthographic and morphological processing?, Cognition, vol.118, issue.2, pp.141-56, 2011. ,
DOI : 10.1016/j.cognition.2010.11.013
Quantitative application of the primary progressive aphasia consensus criteria, Neurology, vol.82, issue.13, pp.1119-1145, 2014. ,
DOI : 10.1212/WNL.0000000000000261
What role does the anterior temporal lobe play in sentence-level processing?, p.34, 2014. ,
Language systems in normal and aphasic human subjects: functional imaging studies and inferences from animal studies, British Medical Bulletin, vol.65, issue.1, pp.95-119, 2003. ,
DOI : 10.1093/bmb/65.1.95
URL : https://academic.oup.com/bmb/article-pdf/65/1/95/9739490/95.pdf
Detecting changes in nonisotropic images, Human Brain Mapping, vol.7, issue.2-3, pp.98-101, 1999. ,
DOI : 10.1002/(SICI)1097-0193(1999)8:2/3<98::AID-HBM5>3.0.CO;2-F
URL : http://www.math.mcgill.ca/~keith/bm98/bm98.pdf
