A new McKean-Vlasov stochastic interpretation of the parabolic-parabolic Keller-Segel model: The one-dimensional case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
Denis Talay
  • Fonction : Auteur
  • PersonId : 833429
Milica Tomasevic
In this paper we analyze a stochastic interpretation of the one-dimensional parabolic-parabolic Keller-Segel system without cut-off. It involves an original type of McKean-Vlasov interaction kernel. At the particle level, each particle interacts with all the past of each other particle by means of a time integrated functional involving a singular kernel. At the mean-field level studied here, the McKean-Vlasov limit process interacts with all the past time marginals of its probability distribution in a similarly singular way. We prove that the parabolic-parabolic Keller-Segel system in the whole Euclidean space and the corresponding McKean-Vlasov stochastic differential equation are well-posed for any values of the parameters of the model.
article-KS-1d-verision-12-Feb.pdf (413.21 Ko) Télécharger le fichier
hal-01673332 , version 1 (29-12-2017)
hal-01673332 , version 2 (19-01-2018)
hal-01673332 , version 3 (13-02-2018)
hal-01673332 , version 4 (03-09-2018)
hal-01673332 , version 5 (06-09-2018)
hal-01673332 , version 6 (25-07-2019)
Denis Talay, Milica Tomasevic. A new McKean-Vlasov stochastic interpretation of the parabolic-parabolic Keller-Segel model: The one-dimensional case. 2018. ⟨hal-01673332v3⟩
882 Consultations
658 Téléchargements
