Proof certificates in PVS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The purpose of this work is to allow the proof system PVS to export proof certificates that can be checked externally. This is done through the instrumentation of PVS to record detailed proofs step by step during the proof search process. At the current stage of this work, proofs can be built for any PVS theory. However, some reasoning steps rely on unverified assumptions. For a restricted fragment of PVS, the proofs are exported to the universal proof checker Dedukti, and the un-verified assumptions are proved externally using the automated theorem prover MetiTarski.
main.pdf (203.69 Ko) Télécharger le fichier
hal-01673517 , version 1 (30-12-2017)
Frédéric Gilbert. Proof certificates in PVS. ITP 2017 - 8th International Conference on Interactive Theorem Proving, Sep 2017, Brasilia, Brazil. pp.262-268, ⟨10.1007/978-3-319-66107-0_17⟩. ⟨hal-01673517⟩
181 Consultations
230 Téléchargements
