The Coq Proof Assistant, version 8.7.1 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2017
Coq is a formal proof management system. It provides a formal language to write mathematical definitions, executable algorithms and theorems together with an environment for semi-interactive development of machine-checked proofs. Typical applications include the certification of properties of programming languages (e.g. the CompCert compiler certification project, or the Bedrock verified low-level programming library), the formalization of mathematics (e.g. the full formalization of the Feit-Thompson theorem or homotopy type theory) and teaching.
Fichier non déposé
hal-01673716 , version 1 (31-12-2017)
The Coq Development Team. The Coq Proof Assistant, version 8.7.1. 2017, pp.1-571. ⟨10.5281/zenodo.1133970⟩. ⟨hal-01673716⟩
263 Consultations
0 Téléchargements
