Atomistic Mechanisms for the Nucleation of Aluminum Oxide Nanoparticles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Physical Chemistry A Année : 2015
A predictive model for nanoparticle nucleation has not yet been successfully achieved. Classical nucleation theory fails because the atomistic nature of the seed has to be considered. Indeed, geometrical structure as well as stoichiometry do not always match the bulk values. We present a fully microscopic approach based on a first-principle study of aluminum oxide clusters. We calculated stable structures of AlxOy and their associated thermodynamic properties. From these data, the chemical composition of a gas composed of aluminum and oxygen atoms can be calculated as a function of temperature, pressure, and aluminum to oxygen ratio. We demonstrate the accuracy of this approach in reproducing experimental results obtained with time-resolved spectroscopy of a laser-induced plasma from an Al2O3 target. We thus extended the calculation to lower temperatures, i.e., longer time scales, to propose a scenario of composition gas evolution leading to the first alumina seeds.
1707.08434.pdf (5.86 Mo) Télécharger le fichier
hal-01673976 , version 1 (07-12-2023)
Julien Lam, David Amans, Christophe Dujardin, Gilles Ledoux, Abdul-Rahman Allouche. Atomistic Mechanisms for the Nucleation of Aluminum Oxide Nanoparticles. Journal of Physical Chemistry A, 2015, 119 (33), pp.8944 - 8949. ⟨10.1021/acs.jpca.5b05829⟩. ⟨hal-01673976⟩
39 Consultations
8 Téléchargements
