Inverse problems in groundwater modeling, 1994. ,
DOI : 10.1007/978-94-017-1970-4
Extreme methods for solving ill-posed problems with applications to inverse heat transfer problems, 1995. ,
DOI : 10.1007/bf01254725
State of the art report on mathematical methods for groundwater pollution source identification. Environmental forensics, pp.205-214, 2001. ,
An inverse problem in estimating the strength of contaminant source for groundwater systems, Applied Mathematical Modelling, vol.32, issue.4, pp.417-431, 2008. ,
DOI : 10.1016/j.apm.2006.12.009
The inverse problem of source reconstruction for convective diffusion equation, Matematicheskoe Modelirovanie, vol.7, issue.11, pp.95-108, 1995. ,
On an inverse problem in the parabolic equation arising from groundwater pollution problem. Boundary Value Problems, p.67, 2015. ,
Review of Parameter Identification Procedures in Groundwater Hydrology: The Inverse Problem, Water Resources Research, vol.19, issue.1, pp.95-108, 1986. ,
DOI : 10.2118/5524-PA
40 years of inverse problems in hydrogeology. Comptes Rendus de l'Academie des Sciences Series IIA Earth and Planetary Science, pp.73-87, 1999. ,
Groundwater inverse problem: Discussion on geostatistical formulations and validation, Hydrogeologie, vol.4, pp.313-324, 1993. ,
DOI : 10.1016/0309-1708(91)90039-q
A geostatistical approach to the inverse problem in groundwater modeling (steady state) and one-dimensional simulations. Water resources research, pp.677-690, 1983. ,
A Comparison of Several Methods for the Solution of the Inverse Problem in Two-Dimensional Steady State Groundwater Flow Modeling, Water Resources Research, vol.19, issue.3, pp.705-714, 1986. ,
DOI : 10.1029/WR019i003p00677
Investigation of alternative procedures for estimating ground-water basin parameters, 1975. ,
A Reassessment of the Groundwater Inverse Problem, Water Resources Research, vol.3, issue.3, pp.1131-1161, 1996. ,
DOI : 10.1137/0803029
Incorporation of prior information on parameters into nonlinear regression groundwater flow models: 1. Theory, Water Resources Research, vol.58, issue.302, pp.318-324, 1982. ,
DOI : 10.1080/01621459.1963.10500854
Incorporation of prior information on parameters into nonlinear regression groundwater flow models: 2. Applications, Water Resources Research, vol.19, issue.4, pp.662-676, 1983. ,
DOI : 10.1080/00401706.1977.10489582
Multiscale parametrization for the estimation of a diffusion coefficient in elliptic and parabolic problems, 5th IFAC Symposium on Control of Distributed Parameter Systems, pp.315-324, 1989. ,
A Multiresolution Method for Distributed Parameter Estimation, SIAM Journal on Scientific Computing, vol.14, issue.2, pp.389-405, 1993. ,
DOI : 10.1137/0914024
Refinement and coarsening indicators for adaptive parametrization: application to the estimation of hydraulic transmissivities, Inverse Problems, vol.18, issue.3, p.775, 2001. ,
Adaptive multiscale permeability estimation, Computational Geosciences, vol.7, issue.1, pp.1-25, 2003. ,
DOI : 10.1023/A:1022417923824
An Adaptive Subdivision Algorithm for the Identification of the Diffusion Coefficient in Two-dimensional Elliptic Problems, Journal of Mathematical Modelling and Algorithms, vol.17, issue.3, pp.529-545, 2007. ,
DOI : 10.1016/B978-008043319-6/50036-4
A new refinement indicator for adaptive parameterization: Application to the estimation of the diffusion coefficient in an elliptic problem, Journal of Computational and Applied Mathematics, vol.224, issue.1, pp.307-319, 2009. ,
DOI : 10.1016/j.cam.2008.05.006
The multidimensional refinement indicators algorithm for optimal parameterization, Journal of Inverse and Ill-Posed Problems, vol.16, pp.107-126, 2008. ,
On the theory and practice of non-linear least-squares, Advances in Water Resources, vol.14, issue.2, pp.55-63, 1991. ,
DOI : 10.1016/0309-1708(91)90051-O
Nonlinear least squres for inverse problems: Theoretical foundations and step-by=step guide for applications, 2009. ,
A finite-element simulation model for saturated-unsaturated, fluid-densitydependent ground-water flow with energy transport or chemically-reactive single-species solute transport US Geological Survey, 1984. ,
Optimisation numérique: aspects théoriques et pratiques, 1997. ,
