SUNNY with Algorithm Configuration
The SUNNY algorithm is a portfolio technique originally tailored for Constraint Satisfaction Problems (CSPs). SUNNY allows to select a set of solvers to be run on a given CSP, and was proven to be effective in the MiniZinc Challenge, i.e., the yearly international competition for CP solvers. In 2015, SUNNY was compared with other solver selectors in the first ICON Challenge on algorithm selection with less satisfactory performance. In this paper we briefly describe the new version of the SUNNY approach for algorithm selection, that was submitted to the first Open Algorithm Selection Challenge.
