Conceptual Framework for Managing Uncertainty in a Collaborative Agri-Food Supply Chain Context - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Agri-food supply chains are subjected to many sources of uncertainty. If these uncertainties are not managed properly, they can have a negative impact on the agri-food supply chain (AFSC) performance, its customers, and the environment. In this sense, collaboration is proposed as a possible solution to reduce it. For that, a conceptual framework (CF) for managing uncertainty in a collaborative context is proposed. In this context, this paper seeks to answer the following research questions: What are the existing uncertainty sources in the AFSCs? Can collaboration be used to reduce the uncertainty of AFSCs? Which elements can integrate a CF for managing uncertainty in a collaborative AFSC? The CF proposal is applied to the weather source of uncertainty in order to show its applicability.
455531_1_En_64_Chapter.pdf (562.4 Ko) Télécharger le fichier
hal-01674874 , version 1 (03-01-2018)
Paternité
Ana Esteso, M. Alemany, Angel Ortiz. Conceptual Framework for Managing Uncertainty in a Collaborative Agri-Food Supply Chain Context. 18th Working Conference on Virtual Enterprises (PROVE), Sep 2017, Vicenza, Italy. pp.715-724, ⟨10.1007/978-3-319-65151-4_64⟩. ⟨hal-01674874⟩
114 Consultations
74 Téléchargements
