How to Make Industrial Symbiosis Profitable - Archive ouverte HAL Access content directly
Conference Papers Year : 2017
(1, 2) , (2) , (3)
1
2
3
Industrial symbiosis can well represent a new kind of collaborative network which demands resolute attention to the flow management of materials, by-products, and waste through local and regional economies. Industrial symbiosis engages traditionally separate companies in a collaborative approach to competitive advantage involving physical exchange of different kind of products which are usually disregard by traditional market transitions. The identification of innovative models to support decision-making process in this kind of networks is urgent since it is necessary to close the loop assuring profitability at a single node as well as at system level. This paper proposes the application of the bi-level optimization model as a way to handle this two-stage problem organized into two cooperating layers. As a preliminary result, the model is applied to a simplified case where the nodes can sell their output to the market or share them in the industrial symbiosis to increase the global efficiency.
455531_1_En_54_Chapter.pdf (938.91 Ko) Télécharger le fichier
Dates and versions
hal-01674880 , version 1 (03-01-2018)
Attribution - CC BY 4.0
Identifiers
Cite
Mohammadtaghi Falsafi, Rosanna Fornasiero, Umberto Dellepiane. How to Make Industrial Symbiosis Profitable. 18th Working Conference on Virtual Enterprises (PROVE), Sep 2017, Vicenza, Italy. pp.614-625, ⟨10.1007/978-3-319-65151-4_54⟩. ⟨hal-01674880⟩
55 View
95 Download
Share
