From spec to verication closure: a case study of applying uvm-ms for rst pass success to a complex mixed-signal soc design, Design and Verication Conference, 2012. ,
Mixed-signal system-on-a-chip (soc) verication based on systemverilog model, System Theory (SSST), 45th Southeastern Symposium on, p.1721, 2013. ,
Uvmbased verication of smart-sensor systems, Synthesis, Modeling, Analysis and Simulation Methods and Applications to Circuit Design (SMACD), International Conference on, p.2124, 2012. ,
Predicting the correlation between analog behavioral models and spice circuits for robust soc verication, Behavioral Modeling and Simulation Workshop, Proceedings of the 2008 IEEE International, p.130135, 2008. ,
Metric driven verication of mixed-signal designs, Design and Verication Conference, 2011. ,
A transaction-oriented UVM-based library for verication of analog behavior, Design Automation Conference (ASP-DAC), 2014 19th Asia and South Pacic, p.806811, 2014. ,
Comparing Two Analog Waveforms -A Trivial Task? In: Zuverlässigkeit und Entwurf, p.153154, 2008. ,
The Earth Mover's Distance as a Metric for Image Retrieval, International Journal of Computer Vision, vol.40, issue.2, p.99121, 2000. ,
Finding Color and Shape Patterns in Images, 1999. ,
Computation of Discrete Fréchet Distance using CNN, Cellular Nanoscale Networks and Their Applications (CNNA), p.16, 2010. ,
Pattern Recognition, 2008. ,
DOI : 10.1016/B0-12-227240-4/00132-5
Similarity based virtual screening using frequency-based weightingschemes: Eect of the choice of similarity coecient, Poster presentation at the Ninth International Conference on Chemical Structures, 2011. ,
How good is the simplex algorithm?, InequalitiesIII: Proceedings of the Third Symposium on Inequalities Held at the University of California, p.159175, 1969. ,
Fast Template Matching Based on Normalized Cross Correlation with Centroid Bounding, 2010 International Conference on Measuring Technology and Mechatronics Automation, p.224227, 2010. ,
DOI : 10.1109/ICMTMA.2010.419
Computing Discrete Fréchet Distance, 1994. ,
