Conference papers
Logic Synthesis for Silicon and Beyond-Silicon Multi-gate Pass-Logic Circuits
Abstract : In the last decade several new technologies have been proposed as possible replacement for MOSFETs; Silicon Nanowires, Magnetic Tunnel Junctions, Graphene p-n Junctions are just some of the most representative examples. Although their intrinsic differences, they all share a common key characteristic, i.e., enable the implementation of logic gates with an expressive power much higher than that of state-of-art silicon CMOS gates. This may translate into more complex and faster switching functions that count less devices. The view of new materials that can serve as technological vehicles for energy efficient circuits and systems attracted the interested of the whole electronics research community. Apart from the many technological aspects, the path towards large-scale integration of emerging devices crosses the need of (i) new integration strategies that better fit the characteristics of the new technologies and (ii) new computer-aided design (CAD) methodologies able to cope with the complexity of today’s design specs. The availability of this two elements may open the way for fast design space exploration and better assessment of new technologies against standard CMOS.This work focuses on logic synthesis and optimization tools for ultra-low power pass-gate circuits mapped into emerging technologies, Graphene and silicon nano-wires. More specifically, we describe a novel multi-function decomposition engine that (i) efficiently performs abstract circuit modeling through a highly-compact data structure called Multi-Function Pass Diagram (MFPD), (ii) provides an effective multi-gate synthesis & optimization flow, (iii) allows accurate power/delay estimations. The contents reported in the following sections represent one of the first examples of how dedicated algorithms and data-structures can substantially improve the quality-of-design when moving from CMOS to emerging technologies.Simulation run conducted on different benchmarks demonstrate that pass-gate circuits synthesized with the proposed tool are smaller and shallower, hence less power hungry and faster than circuits obtained through conventional synthesis methodologies based on standard design flows. As an additional contribution, the results prove that our solution is not only applicable to beyond-silicon technologies but also to standard MOSFETs.
Document type :
Conference papers
Complete list of metadata
Cited literature [30 references]  Display  Hide  Download
https://hal.inria.fr/hal-01675195
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Thursday, January 4, 2018 - 10:59:59 AM
Last modification on : Tuesday, November 30, 2021 - 2:32:02 PM
Long-term archiving on: : Thursday, May 3, 2018 - 12:43:39 PM
File
456609_1_En_4_Chapter.pdf
Identifiers
Citation
Valerio Tenace, Andrea Calimera, Enrico Macii, Massimo Poncino. Logic Synthesis for Silicon and Beyond-Silicon Multi-gate Pass-Logic Circuits. 24th IFIP/IEEE International Conference on Very Large Scale Integration - System on a Chip (VLSISOC), Sep 2016, Tallinn, Estonia. pp.60-82, ⟨10.1007/978-3-319-67104-8_4⟩. ⟨hal-01675195⟩
Share
Metrics
Record views
123
Files downloads
63
