Robust Hybrid TFET-MOSFET Circuits in Presence of Process Variations and Soft Errors
In this work, to improve the timing yield of Tunnel Field Effect Transistor (TFET) circuits in the presence of process variations as well as their soft-error resiliency, we propose replacing some of TFET-based gates by MOSFET-based ones. The effectiveness of the proposed TFET-MOSFET hybrid implementation of the circuits are investigated by first studying the impacts of the process variation on the performances (I-V characteristics) of both homojunction InAs TFETs and MOSFETs. Next, to analyze the soft error rate of the circuits, the particle hit-induced transient current profiles of these devices are extracted. Based on these studies, a hybrid TFET-MOSFET circuit design approach which improves the reliability and soft-error resiliency compared to those of pure TFET-based circuits is suggested. Finally, the efficacy of the design approach is investigated by applying it to some circuits of ISCAS’89 benchmark package.
