Beyond Time-Triggered Co-simulation of Cyber-Physical Systems for Performance and Accuracy Improvements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Cyber-Physical Systems consist of cyber components controlling physical entities. Their development involves different engineering disciplines, that use different models, written in languages with different semantics. A coupled simulation of these models is of prime importance to rapidly understand the emerging system behavior. The coupling of the simulations is realized by a coordinator that conveys data and ensures time consistency between the different models/simulators. Existing coordinators are usually time triggered. In this paper we show that time-triggered coordinators may introduce poor performance and accuracy (both temporal and functional) when used to co-simulate cyber-physical models. Therefore, we propose a new coordinator mixing time-and event-triggered mechanisms. We validated the approach in the context of the FMI standard for co-simulation. To make possible the writing of the new coordinators , we implemented backward compatible extensions to the FMI API. Also, we implemented a new FMI exporter in an industrial tool.
rapido2018_noACM.pdf (847.68 Ko) Télécharger le fichier
hal-01675396 , version 1 (04-01-2018)
  • HAL Id : hal-01675396 , version 1
Giovanni Liboni, Julien Deantoni, Antonio Portaluri, Davide Quaglia, Robert de Simone. Beyond Time-Triggered Co-simulation of Cyber-Physical Systems for Performance and Accuracy Improvements. 10th Workshop on Rapid Simulation and Performance Evaluation: Methods and Tools, Jan 2018, Manchester, United Kingdom. ⟨hal-01675396⟩
353 Consultations
380 Téléchargements
