Subcubic Equivalences Between Graph Centrality Problems, APSP and Diameter, SODA'15, pp.1681-1697 ,
DOI : 10.1137/1.9781611973730.112
URL : http://theory.stanford.edu/%7Evirgi/betw.pdf
Popular Conjectures Imply Strong Lower Bounds for Dynamic Problems, 2014 IEEE 55th Annual Symposium on Foundations of Computer Science, pp.434-443 ,
DOI : 10.1109/FOCS.2014.53
Approximation and Fixed Parameter Subquadratic Algorithms for Radius and Diameter in Sparse Graphs, Proceedings of the Twenty-Seventh Annual ACM-SIAM Symposium on Discrete Algorithms, pp.377-391 ,
DOI : 10.1137/1.9781611974331.ch28
Tree-like P4-connected graphs, Discrete Mathematics, vol.191, issue.1-3, pp.13-23, 1998. ,
DOI : 10.1016/S0012-365X(98)00088-0
URL : https://doi.org/10.1016/s0012-365x(98)00088-0
Recognition and isomorphism of tree-like P4-connected graphs, Discrete Applied Mathematics, vol.99, issue.1-3, pp.295-315, 2000. ,
DOI : 10.1016/S0166-218X(99)00140-7
On the structure of graphs with few P4s, Discrete Applied Mathematics, vol.84, issue.1-3, pp.1-31, 1998. ,
DOI : 10.1016/S0166-218X(97)90120-7
On the p-connectedness of graphs ??? a survey, Discrete Applied Mathematics, vol.95, issue.1-3, pp.11-33, 1999. ,
DOI : 10.1016/S0166-218X(99)00062-1
Distance-hereditary graphs, Journal of Combinatorial Theory, Series B, vol.41, issue.2 ,
DOI : 10.1016/0095-8956(86)90043-2
URL : https://doi.org/10.1016/0095-8956(86)90043-2
Parameterized Aspects of Triangle Enumeration, FCT'17, pp.96-110 ,
DOI : 10.1109/ICDE.2012.35
TWO THEOREMS IN GRAPH THEORY, Proceedings of the National Academy of Sciences, vol.43, issue.9, pp.842-844, 1957. ,
DOI : 10.1073/pnas.43.9.842
URL : http://doi.org/10.1073/pnas.43.9.842
Treewidth: Characterizations, Applications, and Computations, WG'06, pp.1-14 ,
DOI : 10.1007/11917496_1
URL : http://www.cs.uu.nl/research/techreps/repo/CS-2006/2006-041.pdf
Graph theory, Grad. Texts in Math, vol.244, 2008. ,
DOI : 10.1007/978-1-84628-970-5
On Computing the Hyperbolicity of Real-World Graphs, ESA'15, pp.215-226 ,
DOI : 10.1080/15326349.2013.838510
URL : https://hal.archives-ouvertes.fr/hal-01199860
Into the Square: On the Complexity of Some Quadratic-time Solvable Problems, Electronic Notes in Theoretical Computer Science, vol.322, pp.51-67, 2016. ,
DOI : 10.1016/j.entcs.2016.03.005
URL : https://hal.archives-ouvertes.fr/hal-01390131
Linear Time Split Decomposition Revisited, SIAM Journal on Discrete Mathematics, vol.26, issue.2, pp.499-514, 2012. ,
DOI : 10.1137/10080052X
URL : https://hal.archives-ouvertes.fr/hal-00921774
Polynomial Time Recognition of Clique- Width ? 3 Graphs, pp.126-134 ,
URL : https://hal.archives-ouvertes.fr/hal-01274081
A Linear Recognition Algorithm for Cographs, SIAM Journal on Computing, vol.14, issue.4, pp.926-934, 1985. ,
DOI : 10.1137/0214065
On the Relationship Between Clique-Width and Treewidth, SIAM Journal on Computing, vol.34, issue.4, pp.825-847, 2005. ,
DOI : 10.1137/S0097539701385351
Recognition of $C_4$-Free and 1/2-Hyperbolic Graphs, SIAM Journal on Discrete Mathematics, vol.28, issue.3, pp.1601-1617, 2014. ,
DOI : 10.1137/140954787
URL : https://hal.archives-ouvertes.fr/hal-01070768
Fully polynomial FPT algorithms for some classes of bounded cliquewidth graphs, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01676187
The monadic second-order logic of graphs. I. recognizable sets of finite graphs. Information and computation, pp.12-75, 1990. ,
URL : https://hal.archives-ouvertes.fr/hal-00353765
On the model-checking of monadic second-order formulas with edge set quantifications, Discrete Applied Mathematics, vol.160, issue.6, pp.866-887, 2012. ,
DOI : 10.1016/j.dam.2010.12.017
URL : https://hal.archives-ouvertes.fr/hal-00481735
Handle-rewriting hypergraph grammars, Journal of Computer and System Sciences, vol.46, issue.2, pp.218-270, 1993. ,
DOI : 10.1016/0022-0000(93)90004-G
URL : https://doi.org/10.1016/0022-0000(93)90004-g
A characterisation of clique-width through nested partitions, Theory of Computing Systems, pp.70-81125, 2000. ,
DOI : 10.1016/j.dam.2015.02.016
URL : https://hal.archives-ouvertes.fr/hal-01022109
Upper bounds to the clique width of graphs Decomposition of directed graphs, Discrete Applied Mathematics SIAM Journal on Algebraic Discrete Methods, vol.101, issue.32, pp.77-114214, 1982. ,
On greedy matching ordering and greedy matchable graphs, WG'97, pp.184-198 ,
DOI : 10.1007/BFb0024498
LexBFS-orderings of distance-hereditary graphs with application to the diametral pair problem, Discrete Applied Mathematics, vol.98, issue.3, pp.191-207, 2000. ,
DOI : 10.1016/S0166-218X(99)00157-2
Linear-Time Approximation for Maximum Weight Matching, Journal of the ACM, vol.61, issue.1, 2014. ,
DOI : 10.6028/jres.069B.009
URL : http://web.eecs.umich.edu/~pettie/papers/ApproxMWM-JACM.pdf
Metric properties of large graphs, 2016. ,
URL : https://hal.archives-ouvertes.fr/tel-01485328
Paths, trees, and flowers, Journal canadien de math??matiques, vol.17, issue.0, pp.449-467, 1965. ,
DOI : 10.4153/CJM-1965-045-4
How to Solve NP-hard Graph Problems on Clique-Width Bounded Graphs in Polynomial Time, WG'11, pp.117-128 ,
DOI : 10.1007/3-540-45477-2_12
Tight Hardness Results for Distance and Centrality Problems in Constant Degree Graphs, 2016. ,
Clique-Width is NP-Complete, SIAM Journal on Discrete Mathematics, vol.23, issue.2, pp.909-939, 2009. ,
DOI : 10.1137/070687256
When Can Graph Hyperbolicity Be Computed in Linear Time?, WADS'17, pp.397-408 ,
DOI : 10.1137/1.9781611973730.111
Fully polynomial-time parameterized computations for graphs and matrices of low treewidth, Proceedings of the Twenty-Eighth Annual ACM-SIAM Symposium on Discrete Algorithms, pp.1419-1432 ,
DOI : 10.1137/1.9781611974782.92
BIPARTITE GRAPHS TOTALLY DECOMPOSABLE BY CANONICAL DECOMPOSITION, International Journal of Foundations of Computer Science, vol.60, issue.04, pp.513-533, 1999. ,
DOI : 10.1016/S0020-0190(98)00173-2
URL : https://hal.archives-ouvertes.fr/hal-00467645
An O(n) time algorithm for maximum matching in P4-tidy graphs, Information Processing Letters, vol.62, issue.6, pp.281-287, 1997. ,
DOI : 10.1016/S0020-0190(97)00081-1
Computing the Gromov hyperbolicity of a discrete metric space, Information Processing Letters, vol.115, issue.6-8, pp.576-579, 2015. ,
DOI : 10.1016/j.ipl.2015.02.002
A Set of Measures of Centrality Based on Betweenness, Sociometry, vol.40, issue.1, pp.35-41, 1977. ,
DOI : 10.2307/3033543
A linear-time algorithm for a special case of disjoint set union, STOC'83, pp.246-251 ,
Parameterized Algorithms for Modular-Width, IPEC'13, pp.163-176 ,
DOI : 10.1007/978-3-319-03898-8_15
On a class of O(n2) problems in computational geometry, Computational Geometry, vol.5, issue.3, pp.165-185, 1995. ,
DOI : 10.1016/0925-7721(95)00022-2
Transitiv orientierbare Graphen, Acta Mathematica Academiae Scientiarum Hungaricae, vol.51, issue.1-2, pp.25-66, 1967. ,
DOI : 10.4153/CJM-1964-055-5
Distance labeling scheme and split decomposition, Discrete Mathematics, vol.273, issue.1-3, pp.115-130, 2003. ,
DOI : 10.1016/S0012-365X(03)00232-2
URL : https://hal.archives-ouvertes.fr/lirmm-00090364
On P4-tidy graphs, Discrete Mathematics and Theoretical Computer Science, vol.1, 1997. ,
URL : https://hal.archives-ouvertes.fr/hal-00955688
Polynomial fixed-parameter algorithms: A case study for longest path on interval graphs, Theoretical Computer Science, vol.689, 2017. ,
DOI : 10.1016/j.tcs.2017.05.017
Split decomposition and graph-labelled trees: Characterizations and fully dynamic algorithms for totally decomposable graphs, Discrete Applied Mathematics, vol.160, issue.6, pp.708-733, 2012. ,
DOI : 10.1016/j.dam.2011.05.007
URL : https://hal.archives-ouvertes.fr/lirmm-00783420
ON THE CLIQUE-WIDTH OF SOME PERFECT GRAPH CLASSES, International Journal of Foundations of Computer Science, vol.11, issue.03, pp.423-443, 2000. ,
DOI : 10.1002/(SICI)1097-0118(199902)30:2<121::AID-JGT6>3.0.CO;2-1
Hyperbolic Groups, Essays in group theory, pp.75-263, 1987. ,
DOI : 10.1007/978-1-4613-9586-7_3
The tree-width of cliquewidth bounded graphs without Kn,n, WG'00, pp.196-205 ,
A survey of the algorithmic aspects of modular decomposition, Computer Science Review, vol.4, issue.1, pp.41-59, 2010. ,
DOI : 10.1016/j.cosrev.2010.01.001
Computing graph distances parameterized by treewidth and diameter, IPEC'16, pp.1-1611 ,
Which problems have strongly exponential complexity?, FOCS'98, pp.653-662 ,
DOI : 10.1109/sfcs.1998.743516
URL : http://dimacs.rutgers.edu/~dieter/Seminar/Papers/ipz-strongexp.ps
P-Components and the Homogeneous Decomposition of Graphs, SIAM Journal on Discrete Mathematics, vol.8, issue.3, pp.448-463, 1995. ,
DOI : 10.1137/S0895480191196812
Sur les assemblages de lignes., Journal f??r die reine und angewandte Mathematik (Crelles Journal), vol.1869, issue.70, p.81, 1869. ,
DOI : 10.1515/crll.1869.70.185
Maximum matching in sparse random graphs, 22nd Annual Symposium on Foundations of Computer Science (sfcs 1981), pp.364-375 ,
DOI : 10.1109/SFCS.1981.21
), SIAM Journal on Computing, vol.36, issue.2, pp.310-325, 2006. ,
DOI : 10.1137/S0097539704441435
Algorithmic Meta-theorems for Restrictions of Treewidth, Algorithmica, vol.4, issue.3, pp.19-37, 2012. ,
DOI : 10.1287/moor.8.4.538
Autour de la décomposition en coupes, 2001. ,
'S, International Journal of Foundations of Computer Science, vol.6, issue.03, pp.329-348, 1999. ,
DOI : 10.1016/0166-218X(94)90026-4
The power of data reduction for matching, MFCS'17 ,
An O( ? V E) algorithm for finding maximum matching in general graphs, FOCS'80, pp.17-27 ,
Fast parallel algorithms for the modular decomposition, 1989. ,
Weak bipolarizable graphs, Discrete Mathematics, vol.74, issue.1-2, pp.159-171, 1989. ,
DOI : 10.1016/0012-365X(89)90208-2
URL : https://doi.org/10.1016/0012-365x(89)90208-2
Approximating clique-width and branch-width, Journal of Combinatorial Theory, Series B, vol.96, issue.4, pp.514-528, 2006. ,
DOI : 10.1016/j.jctb.2005.10.006
URL : https://doi.org/10.1016/j.jctb.2005.10.006
Topology manipulations for speeding betweenness centrality computation, Journal of Complex Networks, vol.3, issue.1, pp.84-112, 2014. ,
DOI : 10.1093/comnet/cnu015
Clique-width of graphs defined by one-vertex extensions, Discrete Mathematics, vol.308, issue.24, pp.6157-6165, 2008. ,
DOI : 10.1016/j.disc.2007.11.039
URL : https://hal.archives-ouvertes.fr/lirmm-00808032
Solving some NP-complete problems using split decomposition, Discrete Applied Mathematics, vol.156, issue.14, pp.2768-2780, 2008. ,
DOI : 10.1016/j.dam.2007.11.013
URL : https://hal.archives-ouvertes.fr/lirmm-00324549
Graph minors. II. Algorithmic aspects of tree-width, Journal of Algorithms, vol.7, issue.3, pp.309-322, 1986. ,
DOI : 10.1016/0196-6774(86)90023-4
URL : https://doi.org/10.1006/jctb.1996.0059
Fast approximation algorithms for the diameter and radius of sparse graphs, Proceedings of the 45th annual ACM symposium on Symposium on theory of computing, STOC '13, pp.515-524 ,
DOI : 10.1145/2488608.2488673
Quelques propriétés topologiques des graphes et applicationsàapplicationsà internet et aux réseaux, 2011. ,
Graphs indecomposable with respect to the X-join, Discrete Mathematics, vol.6, issue.3, pp.281-298, 1973. ,
DOI : 10.1016/0012-365X(73)90100-3
Simpler Linear-Time Modular Decomposition Via Recursive Factorizing Permutations, ICALP'08, pp.634-645 ,
DOI : 10.1007/978-3-540-70575-8_52
URL : http://www.cs.utoronto.ca/~mtedder/TedderModular.pdf
Hardness of easy problems: Basing hardness on popular conjectures such as the strong exponential time hypothesis (Invited talk), IPEC'15, pp.16-28 ,
Subcubic Equivalences between Path, Matrix and Triangle Problems, 2010 IEEE 51st Annual Symposium on Foundations of Computer Science, pp.645-654 ,
DOI : 10.1109/FOCS.2010.67
An O(n) time algorithm for maximum matching on cographs, Information Processing Letters, vol.47, issue.2, pp.89-93, 1993. ,
DOI : 10.1016/0020-0190(93)90230-7
