Copysets: Reducing the frequency of data loss in cloud storage, Presented as part of the 2013 USENIX Annual Technical Conference (USENIX ATC 13), pp.2013-2050 ,
Benchmarking cloud serving systems with ycsb, Proceedings of the 1st ACM Symposium on Cloud Computing SoCC '10, pp.143-154, 2010. ,
Dynamo: Amazon's highly available key-value store, Proceedings of Twenty-first ACM SIGOPS Symposium on Operating Systems Principles SOSP '07, pp.205-220, 2007. ,
Farm: Fast remote memory, Proceedings of the 11th USENIX Conference on Networked Systems Design and Implementation NSDI'14, USENIX Association, pp.401-414 ,
No compromises: Distributed transactions with consistency, availability, and performance, Proceedings of the 25th Symposium on Operating Systems Principles SOSP '15, pp.54-70 ,
Rdma based replication of multiprocessor virtual machines over high-performance interconnects, IEEE International Conference on Cluster Computing, pp.35-44, 2011. ,
Incremental consistency guarantees for replicated objects, 12th USENIX Symposium on Operating Systems Design and Implementation (OSDI 16) (GA, 2016), USENIX Association, pp.169-184 ,
High performance mpi-2 one-sided communication over infiniband, IEEE International Symposium on Cluster Computing and the Grid, pp.531-538, 2004. ,
Scalability of write-ahead logging on multicore and multisocket hardware, The VLDB Journal, vol.21, issue.2, pp.239-263, 2012. ,
Using rdma efficiently for key-value services, Proceedings of the 2014 ACM Conference on SIGCOMM SIGCOMM '14, ACM, pp.295-306 ,
Design guidelines for high performance RDMA systems, 2016 USENIX Annual Technical Conference (USENIX ATC 16) USENIX Association, pp.437-450 ,
Fasst: Fast, scalable and simple distributed transactions with two-sided (rdma) datagram rpcs, Proceedings of the 12th USENIX Conference on Operating Systems Design and Implementation OSDI'16, USENIX Association, pp.185-201 ,
Kafka: A distributed messaging system for log processing, Proceedings of 6th International Workshop on Networking Meets Databases (NetDB), 2011. ,
Making geo-replicated systems fast as possible, consistent when necessary, Presented as part of the 10th USENIX Symposium on Operating Systems Design and Implementation (OSDI 12) USENIX, pp.2012-265 ,
Using one-sided rdma reads to build a fast, cpu-efficient key-value store, Proceedings of the 2013 USENIX Conference on Annual Technical Conference USENIX ATC'13, USENIX Association, pp.103-114 ,
Balancing CPU and network in the cell distributed b-tree store, 2016 USENIX Annual Technical Conference (USENIX ATC 16) USENIX Association, pp.451-464 ,
Timely: Rtt-based congestion control for the datacenter, Proceedings of the 2015 ACM Conference on Special Interest Group on Data Communication SIGCOMM '15, pp.2015-537 ,
Aries: A transaction recovery method supporting fine-granularity locking and partial rollbacks using writeahead logging, ACM Trans. Database Syst, vol.17, issue.1, pp.94-162, 1992. ,
ARMCI: A portable remote memory copy library for distributed array libraries and compiler run-time systems, pp.533-546, 1999. ,
Scaling memcache at facebook, Presented as part of the 10th USENIX Symposium on Networked Systems Design and Implementation (NSDI 13) USENIX, pp.385-398 ,
Fast crash recovery in ramcloud, Proceedings of the Twenty-Third ACM Symposium on Operating Systems Principles, pp.29-41, 2011. ,
The ramcloud storage system, ACM Trans. Comput. Syst, vol.33, issue.7, pp.31-755, 2015. ,
Dare: High-performance state machine replication on rdma networks, Proceedings of the 24th International Symposium on High-Performance Parallel and Distributed Computing HPDC '15, ACM, pp.107-118 ,
Analysis and evolution of journaling file systems, Proceedings of the Annual Conference on USENIX Annual Technical Conference ATEC '05, USENIX Association, pp.8-8, 2005. ,
Introducing cloudlab: Scientific infrastructure for advancing cloud architectures and applications, pp.39-45, 2014. ,
The design and implementation of a log-structured file system, ACM Trans. Comput . Syst, vol.10, issue.1, pp.26-52, 1992. ,
Logstructured memory for dram-based storage, Proceedings of the 12th USENIX Conference on File and Storage Technologies FAST'14, USENIX Association, pp.1-16 ,
Fast and concurrent RDF queries with rdma-based distributed graph exploration, 12th USENIX Symposium on Operating Systems Design and Implementation (OSDI 16) (GA, 2016), USENIX Association, pp.317-332 ,
The hadoop distributed file system, Proceedings of the 2010 IEEE 26th Symposium on Mass Storage Systems and Technologies (MSST) MSST '10, pp.1-10, 2010. ,
Rfp: When rpc is faster than server-bypass with rdma, Proceedings of the Twelfth European Conference on Computer Systems EuroSys '17, ACM, pp.1-15 ,
Characterizing performance and energy-efficiency of the ramcloud storage system, 2017 IEEE 37th International Conference on Distributed Computing Systems (ICDCS), pp.1488-1498, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01496959
Hydradb: A resilient rdmadriven key-value middleware for in-memory cluster computing, Proceedings of the International Conference for High Performance Computing, Networking, Storage and Analysis SC '15, ACM, pp.1-2211 ,
Fast in-memory transaction processing using rdma and htm, Proceedings of the 25th Symposium on Operating Systems Principles SOSP '15, ACM, pp.87-104 ,
Live virtual machine migration via asynchronous replication and state synchronization, IEEE Transactions on Parallel Distributed Systems, vol.22, pp.1986-1999, 2011. ,
Resilient distributed datasets: A fault-tolerant abstraction for in-memory cluster computing, Presented as part of the 9th USENIX Symposium on Networked Systems Design and Implementation (NSDI 12) USENIX, pp.2012-2027 ,
Congestion control for large-scale rdma deployments, Proceedings of the 2015 ACM Conference on Special Interest Group on Data Communication SIGCOMM '15, pp.2015-523 ,
