LISP-Views: Monitoring LISP at Large Scale - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Yue Li
  • Fonction : Auteur
Luigi Iannone
The Locator/Identifier Separation Protocol (LISP) separates classical IP addresses into two categories: one for identifying terminals, the other for routing. To associate identifiers and locators LISP needs a specific mechanism, called mapping system. This technology is still at an early stage but two experimental platforms have already been deployed in the Internet: LISP Beta Network and LISP-Lab. However, only the LISP Beta Network is monitored with LISPmon that partially monitors the mapping system once a day. To accompany the growth of LISP, a dynamic and complete monitoring system is required. Therefore, we propose LISP-Views, a dynamic versatile large scale LISP monitoring architecture. LISP-Views allows to automatically conduct comprehensive and objective measurements. After running LISP-Views in the wild for several months and comparing the monitoring results with LISPmon, we confirm that LISP-Views provides more detailed and accurate information. We observe the different behaviours between every network entity within mapping system, and also explore the current LISP performance for further improvements.
Fichier non déposé
hal-01676534 , version 1 (05-01-2018)
  • HAL Id : hal-01676534 , version 1
Yue Li, Akram Abouseif, Luigi Iannone, Damien Saucez. LISP-Views: Monitoring LISP at Large Scale. 29th International Teletraffic Congress, Sep 2017, Genova, Italy. ⟨hal-01676534⟩
77 Consultations
0 Téléchargements
