On the curves that may be approached by trajectories of a smooth control affine system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Systems and Control Letters Année : 1999
In this paper, we give a characterization of the set of curves that may be approached by trajectories of a smooth control-ane nonlinear system, in the topology of uniform convergence. This characterization is in terms of the drift vector field and the distribution spanned by the Lie algebra generated by the control vector fields. The characterization is valid on open sets where this distribution has constant rank. These results also characterize the support of di↵usion processes with smooth coecients. ⇤
1999-SCLadh.pdf (315.1 Ko) Télécharger le fichier
hal-01677090 , version 1 (08-01-2018)
Jean-Baptiste Pomet. On the curves that may be approached by trajectories of a smooth control affine system. Systems and Control Letters, 1999, 36 (2), pp.143 - 149. ⟨10.1016/S0167-6911(98)00086-3⟩. ⟨hal-01677090⟩
149 Consultations
65 Téléchargements
