HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Quantitative Externalization of Visual Data Analysis Results Using Local Regression Models
Abstract : Both interactive visualization and computational analysis methods are useful for data studies and an integration of both approaches is promising to successfully combine the benefits of both methodologies. In interactive data exploration and analysis workflows, we need successful means to quantitatively externalize results from data studies, amounting to a particular challenge for the usually qualitative visual data analysis. In this paper, we propose a hybrid approach in order to quantitatively externalize valuable findings from interactive visual data exploration and analysis, based on local linear regression models. The models are built on user-selected subsets of the data, and we provide a way of keeping track of these models and comparing them. As an additional benefit, we also provide the user with the numeric model coefficients. Once the models are available, they can be used in subsequent steps of the workflow. A model-based optimization can then be performed, for example, or more complex models can be reconstructed using an inversion of the local models. We study two datasets to exemplify the proposed approach, a meteorological data set for illustration purposes and a simulation ensemble from the automotive industry as an actual case study.
Complete list of metadata
Cited literature [31 references]  Display  Hide  Download
https://hal.inria.fr/hal-01677124
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, January 8, 2018 - 9:49:05 AM
Last modification on : Friday, November 20, 2020 - 4:22:03 PM
Long-term archiving on: : Wednesday, May 23, 2018 - 2:48:43 PM
File
456304_1_En_14_Chapter.pdf
Identifiers
Citation
Hrvoje Abraham, Mario Jelović, Helwig Hauser, Krešimir Matković. Quantitative Externalization of Visual Data Analysis Results Using Local Regression Models. 1st International Cross-Domain Conference for Machine Learning and Knowledge Extraction (CD-MAKE), Aug 2017, Reggio, Italy. pp.199-218, ⟨10.1007/978-3-319-66808-6_14⟩. ⟨hal-01677124⟩
Share
Metrics
Record views
244
Files downloads
59
