Support Vector Regression for Improved Real-Time, Simultaneous Myoelectric Control, IEEE Transactions on Neural Systems and Rehabilitation Engineering, vol.22, issue.6, pp.1198-1209, 2014. ,
DOI : 10.1109/TNSRE.2014.2323576
Directional tuning profiles of motor cortical cells, Neuroscience Research, vol.36, issue.1, pp.73-79, 2000. ,
DOI : 10.1016/S0168-0102(99)00112-1
Differences in Adaptation Rates after Virtual Surgeries Provide Direct Evidence for Modularity, Journal of Neuroscience, vol.33, issue.30, pp.12384-12394, 2013. ,
DOI : 10.1523/JNEUROSCI.0122-13.2013
Behavioral and neural correlates of visuomotor adaptation observed through a brain-computer interface in primary motor cortex, Journal of Neurophysiology, vol.80, issue.2, pp.624-644, 2012. ,
DOI : 10.1007/s002210050462
Design and Analysis of Closed-Loop Decoder Adaptation Algorithms for Brain-Machine Interfaces, Neural Computation, vol.15, issue.7, pp.25-1693, 2013. ,
DOI : 10.1088/1741-2560/3/2/010
Dissociable contribution of the parietal and frontal cortex to coding movement direction and amplitude, Frontiers in Human Neuroscience, vol.9, p.241, 2015. ,
DOI : 10.3389/fnhum.2015.00241
Generalization of visuomotor adaptation to different muscles is less efficient: Experiment and model, Human Movement Science, vol.29, issue.5, pp.684-700, 2010. ,
DOI : 10.1016/j.humov.2010.01.008
Changes in muscle directional tuning parallel feedforward adaptation to a visuomotor rotation, Experimental Brain Research, vol.24, issue.Pt 3, pp.701-709, 2010. ,
DOI : 10.1080/00222895.1993.9941644
Muscle Coordination Is Habitual Rather than Optimal, Journal of Neuroscience, vol.32, issue.21, pp.7384-7391, 2012. ,
DOI : 10.1523/JNEUROSCI.5792-11.2012
Virtual biomechanics: a new method for online reconstruction of force from EMG recordings, Journal of Neurophysiology, vol.14, issue.12, pp.3333-3341, 2012. ,
DOI : 10.1152/jn.00178.2007
The Temporal Evolution of Feedback Gains Rapidly Update to Task Demands, Journal of Neuroscience, vol.33, issue.26, pp.10898-10909, 2013. ,
DOI : 10.1523/JNEUROSCI.5669-12.2013
Quantifying generalization from trial-by-trial behavior of adaptive systems that learn with basis functions: theory and experiments in human motor control, The Journal of neuroscience, vol.23, issue.27, pp.9032-9045, 2003. ,
Towards a real-time interface between a biomimetic model of sensorimotor cortex and a robotic arm, Pattern Recognition Letters, vol.36, pp.204-212, 2014. ,
DOI : 10.1016/j.patrec.2013.05.019
Restoring Behavior via Inverse Neurocontroller in a Lesioned Cortical Spiking Model Driving a Virtual Arm, Frontiers in Neuroscience, vol.17, issue.99, 2016. ,
DOI : 10.1038/nrn3112
The Extraction of Neural Information from the Surface EMG for the Control of Upper-Limb Prostheses: Emerging Avenues and Challenges, IEEE Transactions on Neural Systems and Rehabilitation Engineering, vol.22, issue.4, pp.797-809, 2014. ,
DOI : 10.1109/TNSRE.2014.2305111
Dissociating the Roles of the Cerebellum and Motor Cortex during Adaptive Learning: The Motor Cortex Retains What the Cerebellum Learns, Cerebral Cortex, vol.21, issue.8, pp.1761-1770, 2011. ,
DOI : 10.1093/cercor/bhq246
Mental rotation of the neuronal population vector, Science, vol.243, issue.4888, pp.234-236, 1989. ,
DOI : 10.1126/science.2911737
A high-performance neural prosthesis enabled by control algorithm design, Nature Neuroscience, vol.2009, issue.12, pp.15-1752, 2012. ,
DOI : 10.1038/nature04968
Linear and Nonlinear Regression Techniques for Simultaneous and Proportional Myoelectric Control, IEEE Transactions on Neural Systems and Rehabilitation Engineering, vol.22, issue.2, pp.269-279, 2014. ,
DOI : 10.1109/TNSRE.2014.2305520
URL : http://doi.org/10.1109/tnsre.2014.2305520
Concurrent Adaptation of Human and Machine Improves Simultaneous and Proportional Myoelectric Control, IEEE Transactions on Neural Systems and Rehabilitation Engineering, vol.23, issue.4, pp.618-627, 2015. ,
DOI : 10.1109/TNSRE.2015.2401134
Theoretical models of motor control and motor learning, Routledge handbook of motor control and motor learning pp, pp.7-28, 2013. ,
User adaptation in long-term, open-loop myoelectric training: implications for EMG pattern recognition in prosthesis control, Journal of Neural Engineering, vol.12, issue.4, p.46005, 2015. ,
DOI : 10.1088/1741-2560/12/4/046005
A memory of errors in sensorimotor learning, Science, vol.17, issue.1, pp.1349-1353, 2014. ,
DOI : 10.1523/JNEUROSCI.3071-08.2008
Volitional Control of Neural Activity Relies on the Natural Motor Repertoire, Current Biology, vol.23, issue.5, pp.353-361, 2013. ,
DOI : 10.1016/j.cub.2013.01.027
Empirical evaluation of the improved Rprop learning algorithms, Neurocomputing, vol.50, pp.105-123, 2003. ,
DOI : 10.1016/S0925-2312(01)00700-7
Proportional Myoelectric Control of Robots: Muscle Synergy Development Drives Performance Enhancement, Retainment, and Generalization, IEEE Transactions on Robotics, vol.31, issue.2, pp.259-268, 2015. ,
DOI : 10.1109/TRO.2015.2395731
Exploiting Task Constraints for Self-Calibrated Brain-Machine Interface Control Using Error-Related Potentials, PLOS ONE, vol.5, issue.1, pp.10-0131491, 2015. ,
DOI : 10.1371/journal.pone.0131491.t001
URL : https://hal.archives-ouvertes.fr/hal-01246436
Myoelectric Control of Artificial Limbs???Is There a Need to Change Focus? [In the Spotlight], IEEE Signal Processing Magazine, vol.29, issue.5, pp.152-150, 2012. ,
DOI : 10.1109/MSP.2012.2203480
Extracting Simultaneous and Proportional Neural Control Information for Multiple-DOF Prostheses From the Surface Electromyographic Signal, IEEE Transactions on Biomedical Engineering, vol.56, issue.4, pp.1070-1080, 2009. ,
DOI : 10.1109/TBME.2008.2007967
Motor Learning and Consolidation: The Case of Visuomotor Rotation, Adv. Exp. Med. Biol, vol.629, pp.405-421, 2009. ,
DOI : 10.1007/978-0-387-77064-2_21
Learning of visuomotor transformations for vectorial planning of reaching trajectories, The Journal of neuroscience, vol.20, issue.23, pp.8916-8924, 2000. ,
Flexible Cortical Control of Task-Specific Muscle Synergies, Journal of Neuroscience, vol.32, issue.36, pp.12349-12360, 2012. ,
DOI : 10.1523/JNEUROSCI.5481-11.2012
Closed-Loop Decoder Adaptation on Intermediate Time-Scales Facilitates Rapid BMI Performance Improvements Independent of Decoder Initialization Conditions, IEEE Transactions on Neural Systems and Rehabilitation Engineering, vol.20, issue.4, pp.468-477, 2012. ,
DOI : 10.1109/TNSRE.2012.2185066
Distinct coordinate systems for adaptations of movement direction and extent, Journal of Neurophysiology, vol.62, issue.5, p.326, 2017. ,
DOI : 10.1152/jn.00212.2012
Spinal-Like Regulator Facilitates Control of a Two-Degree-of-Freedom Wrist, Journal of Neuroscience, vol.30, issue.28, pp.9431-9444, 2010. ,
DOI : 10.1523/JNEUROSCI.5537-09.2010
Co-Adaptive and Affective Human-Machine Interface for Improving Training Performances of Virtual Myoelectric Forearm Prosthesis, IEEE Transactions on Affective Computing, vol.3, issue.3, pp.285-297, 2012. ,
DOI : 10.1109/T-AFFC.2012.3
A direct adaptive method for faster backpropagation learning: the RPROP algorithm, IEEE International Conference on Neural Networks, pp.586-591, 1993. ,
DOI : 10.1109/ICNN.1993.298623
Neural constraints on learning, Neural constraints on learning, pp.423-426, 2014. ,
DOI : 10.1037/h0055392
URL : https://www.ncbi.nlm.nih.gov/pmc/articles/PMC4393644/pdf
Feedback control during voluntary motor actions, Current Opinion in Neurobiology, vol.33, pp.85-94, 2015. ,
DOI : 10.1016/j.conb.2015.03.006
Robust Brain-Machine Interface Design Using Optimal Feedback Control Modeling and Adaptive Point Process Filtering, PLOS Computational Biology, vol.11, issue.6, p.1004730, 2016. ,
DOI : 10.1371/journal.pcbi.1004730.s010
URL : http://doi.org/10.1371/journal.pcbi.1004730
Combining Decoder Design and Neural Adaptation in Brain-Machine Interfaces, Neuron, vol.84, issue.4, pp.665-680, 2014. ,
DOI : 10.1016/j.neuron.2014.08.038
URL : https://doi.org/10.1016/j.neuron.2014.08.038
Interacting adaptive processes with di?erent timescales underlie short-term motor learning, PLoS Biol, vol.4, pp.1035-1043, 2006. ,
DOI : 10.1371/journal.pbio.0040179
URL : https://doi.org/10.1371/journal.pbio.0040179
Adaptation to Visuomotor Rotation Through Interaction Between Posterior Parietal and Motor Cortical Areas, Journal of Neurophysiology, vol.15, issue.5, pp.2921-2932, 2009. ,
DOI : 10.1016/0006-8993(78)90036-7
URL : https://www.ncbi.nlm.nih.gov/pmc/articles/PMC2777823/pdf
Feedback-dependent generalization, Journal of Neurophysiology, vol.20, issue.1, pp.202-215, 2013. ,
DOI : 10.1007/s00221-002-1211-9
URL : http://jn.physiology.org/content/jn/109/1/202.full.pdf
Learning of action through adaptive combination of motor primitives, Nature, vol.407, pp.742-747, 2000. ,
Useful properties of spinal circuits for learning and performing planar reaches, Journal of Neural Engineering, vol.11, issue.5, p.56006, 2014. ,
DOI : 10.1088/1741-2560/11/5/056006
Concept of a co-adaptive training environment for human-machine interfaces based on emgcontrol, Biomed Tech, vol.58, 2013. ,
Machine-Learning-Based Coadaptive Calibration for Brain-Computer Interfaces, Neural Computation, vol.8, issue.3, pp.791-816, 2011. ,
DOI : 10.1016/S1388-2457(02)00057-3
Covariate shift adaptation in EMG pattern recognition for prosthetic device control, 2014 36th Annual International Conference of the IEEE Engineering in Medicine and Biology Society, pp.4370-4373, 2014. ,
DOI : 10.1109/EMBC.2014.6944592
Error Parsing in Visuomotor Pointing Reveals Independent Processing of Amplitude and Direction, Journal of Neurophysiology, vol.94, issue.2, pp.1212-1224, 2005. ,
DOI : 10.1007/BF00230024
Ten-dimensional anthropomorphic arm control in a human brain???machine interface: difficulties, solutions, and limitations, Journal of Neural Engineering, vol.12, issue.1, p.16011, 2014. ,
DOI : 10.1088/1741-2560/12/1/016011
