Benchmarking Joint Lexical and Syntactic Analysis on Multiword-Rich Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This article evaluates the extension of a dependency parser that performs joint syntactic analysis and multiword expression identification. We show that, given sufficient training data, the parser benefits from explicit multiword information and improves overall labeled accuracy score in eight of the ten evaluation cases.
MWE201725.pdf (125.61 Ko) Télécharger le fichier
hal-01677416 , version 1 (08-01-2018)
  • HAL Id : hal-01677416 , version 1
Mathieu Constant, Hector Martinez Alonso. Benchmarking Joint Lexical and Syntactic Analysis on Multiword-Rich Data. MWE 2017 - 13th Workshop on Multiword Expressions, Apr 2017, Valencia, Spain. pp.181 - 186. ⟨hal-01677416⟩
207 Consultations
78 Téléchargements
