Human-in-the-Loop Simulation of Cloud Services - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Frank De Boer
  • Fonction : Auteur
  • PersonId : 986104
Stijn De Gouw
  • Fonction : Auteur
  • PersonId : 1026104
In this paper we discuss an integrated tool suite for the simulation of software services which are offered on the Cloud. The tool suite uses the Abstract Behavioral Specification (ABS) language for modeling the software services and their Cloud deployment. For the real-time execution of the ABS models we use a Haskell backend which is based on a source-to-source translation of ABS into Haskell. The tool suite then allows Cloud engineers to interact in real-time with the execution of the model by deploying and managing service instances. The resulting human-in-the-loop simulation of Cloud services can be used both for training purposes and for the (semi-)automated support for the real-time monitoring and management of the actual service instances.
449571_1_En_11_Chapter.pdf (499.16 Ko) Télécharger le fichier
hal-01677612 , version 1 (08-01-2018)
Paternité
Nikolaos Bezirgiannis, Frank De Boer, Stijn De Gouw. Human-in-the-Loop Simulation of Cloud Services. 6th European Conference on Service-Oriented and Cloud Computing (ESOCC), Sep 2017, Oslo, Norway. pp.143-158, ⟨10.1007/978-3-319-67262-5_11⟩. ⟨hal-01677612⟩
110 Consultations
70 Téléchargements
