On Abstraction-Based Deadlock-Analysis in Service-Oriented Systems with Recursion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mandy Weissbach
  • Fonction : Auteur
  • PersonId : 1026110
Wolf Zimmermann
  • Fonction : Auteur
  • PersonId : 1026111
We examine deadlock analysis for service-oriented systems with unbound concurrency and unbound recursion. In particular, abstraction-based approaches are considered, i.e., abstract behavior models are derived from service implementations and composed according to the architecture of service-oriented systems. It turns out that there are some limitations of Petri-net-based approaches, e.g., such as workflow nets if deadlocks are analyzed. We show an example that ends in a deadlock if recursion is considered but on a Petri-net-based abstraction, it may regularly end.
449571_1_En_13_Chapter.pdf (287.65 Ko) Télécharger le fichier
hal-01677617 , version 1 (08-01-2018)
Paternité
Mandy Weissbach, Wolf Zimmermann. On Abstraction-Based Deadlock-Analysis in Service-Oriented Systems with Recursion. 6th European Conference on Service-Oriented and Cloud Computing (ESOCC), Sep 2017, Oslo, Norway. pp.168-176, ⟨10.1007/978-3-319-67262-5_13⟩. ⟨hal-01677617⟩
71 Consultations
65 Téléchargements
