Synchronizing Heuristics: Speeding up the Slowest - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ömer Faruk Altun
  • Fonction : Auteur
  • PersonId : 1026251
Kamil Tolga Atam
  • Fonction : Auteur
  • PersonId : 1026252
Sertaç Karahoda
  • Fonction : Auteur
  • PersonId : 1023371
Computing a shortest synchronizing word of an automaton is an NP–hard problem. Therefore, heuristics are used to compute short synchronizing words. SynchroP is among the best heuristics in the literature in terms of word lengths. The heuristic and its variants such as SynchroPL have been frequently used as a baseline to judge the quality of the words generated by the new heuristics. Although, its quality is good, the heuristics are significantly slow especially compared to much cheaper heuristics such as Greedy and Cycle. This makes them infeasible for large-scale automatons. In this paper, we show how one can improve the time performance of SynchroP and its variants by avoiding unnecessary computations which makes these heuristics more competitive than they already are. Our experimental results show that for 2500 states, SynchroP can be made 70–$$160\times $$ faster, via the proposed optimizations. In particular, for 2500 states and 32 letters, the SynchroP execution reduces to 66 s from 4745 s. Furthermore, the suggested optimizations become more effective as the number of states in the automata increase.
449632_1_En_15_Chapter.pdf (541.02 Ko) Télécharger le fichier
hal-01678975 , version 1 (09-01-2018)
Paternité
Ömer Faruk Altun, Kamil Tolga Atam, Sertaç Karahoda, Kamer Kaya. Synchronizing Heuristics: Speeding up the Slowest. 29th IFIP International Conference on Testing Software and Systems (ICTSS), Oct 2017, St. Petersburg, Russia. pp.243-256, ⟨10.1007/978-3-319-67549-7_15⟩. ⟨hal-01678975⟩
73 Consultations
77 Téléchargements
