Asymptotic Modelling for 3D Eddy Current Problems with a Conductive Thin Layer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work we derive and analyze an equivalent model for 3D Eddy Current problems with a conductive thin layer of small thickness $\epsilon$. In our model, the conductive sheet is replaced by its mid-surface and their shielding behavior is satisfied by an equivalent transmission conditions on this interface. The transmission conditions are derived asymptotically for vanishing sheet thickness $\epsilon$.
ACOMEN2017.pdf (437.49 Ko) Télécharger le fichier
hal-01679683 , version 1 (11-01-2018)
  • HAL Id : hal-01679683 , version 1
Mohammad Issa, Victor Péron, Ronan Perrussel. Asymptotic Modelling for 3D Eddy Current Problems with a Conductive Thin Layer. ACOMEN 2017 - 7th International Conference on Advanced COmputational Methods in ENgineering, Sep 2017, Ghent, Belgium. ⟨hal-01679683⟩
218 Consultations
227 Téléchargements
