Breathing Friend: Tackling Stress Through Portable Tangible Breathing Artifact
We present Breathing Friend – a portable and tangible device that uses haptic interaction to unobtrusively stimulate mindful breathing as efficient stress coping method. Its design is optimized for holding in user’s hands. By changing its shape, it sends haptic signals to the user. Several studies were conducted where we explored and verified the form factors of the artifact, interaction methods, therapeutic effect, fitting to everyday life, and influence on the breathing pattern.
Informatique [cs]
