Abstract : Although the issue of limited mobility affects a large portion of the population, current navigation systems working with roadway-based geodatabases are designed primarily for cars and therefore cannot efficiently help. Usage of the professionally created sidewalk-based geodatabase is a solution. However, the professional geographical “on-site reconnaissance” is labor demanding. In this poster, we report on results of preliminary research focused on a design of the gamified collection of accessibility attributes by non-expert crowd, which will reduce the data collection cost. Preliminary results suggest the feasibility of the approach supported by a proper guidance of non-experts and creativity of achieving precise measurements.
https://hal.inria.fr/hal-01679789 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Wednesday, January 10, 2018 - 11:29:22 AM Last modification on : Tuesday, January 19, 2021 - 10:16:03 AM Long-term archiving on: : Friday, May 4, 2018 - 6:04:23 PM
