Towards Actionable Mission Impact Assessment in the Context of Cloud Computing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Xiaoyan Sun
  • Fonction : Auteur
  • PersonId : 1026633
Peng Liu
  • Fonction : Auteur
  • PersonId : 1026634
Today’s cyber-attacks towards enterprise networks often undermine and even fail the mission assurance of victim networks. Mission cyber resilience (or active cyber defense) is critical to prevent or minimize negative consequences towards missions. Without effective mission impact assessment, mission cyber resilience cannot be really achieved. However, there is an overlooked gap between mission impact assessment and cyber resilience due to the non-mission-centric nature of current research. This gap is even widened in the context of cloud computing. The gap essentially accounts for the weakest link between missions and attack-resilient systems, and also explains why the existing impact analysis is not really actionable. This paper initiates efforts to bridge this gap, by developing a novel graphical model that interconnects the mission dependency graphs and cloud-level attack graphs. Our case study shows that the new cloud-applicable model is able to bridge the gap between mission impact assessment and cyber resilience. As a result, it can significantly improve the effectiveness of cyber resilience analysis of mission critical systems.
453481_1_En_14_Chapter.pdf (954.65 Ko) Télécharger le fichier
hal-01684363 , version 1 (15-01-2018)
Paternité
Xiaoyan Sun, Anoop Singhal, Peng Liu. Towards Actionable Mission Impact Assessment in the Context of Cloud Computing. 31th IFIP Annual Conference on Data and Applications Security and Privacy (DBSEC), Jul 2017, Philadelphia, PA, United States. pp.259-274, ⟨10.1007/978-3-319-61176-1_14⟩. ⟨hal-01684363⟩
114 Consultations
147 Téléchargements
