Journal articles
Backward differentiation formula finite difference schemes for diffusion equations with an obstacle term
Abstract : Finite difference schemes, using Backward Differentiation Formula (BDF), are studied for the approximation of one-dimensional diffusion equations with an obstacle term, of the form $$\min(v_t - a(t,x) v_{xx} + b(t,x) v_x + r(t,x) v, v- \varphi(t,x))= f(t,x).$$ {For the scheme building on the second order BDF formula (BDF2), we discuss unconditional stability, prove an $L^2$-error estimate and show numerically second order convergence, in both space and time, unconditionally on the ratio of the mesh steps. In the analysis, an equivalence of the obstacle equation with a Hamilton-Jacobi-Bellman equation is mentioned, and a Crank-Nicolson scheme is tested in this context. Two academic problems for parabolic equations with an obstacle term with explicit solutions and the American option problem in mathematical finance are used for numerical tests.
Document type :
Journal articles
Complete list of metadata
Cited literature [37 references]  Display  Hide  Download
https://hal.inria.fr/hal-01686742
Contributor : Olivier Bokanowski Connect in order to contact the contributor
Submitted on : Friday, March 6, 2020 - 2:46:38 PM
Last modification on : Sunday, June 26, 2022 - 10:03:34 AM
Long-term archiving on: : Sunday, June 7, 2020 - 2:36:45 PM
File
Bokanowski_Kristian_2020.pdf
Identifiers
Citation
Olivier Bokanowski, Kristian Debrabant. Backward differentiation formula finite difference schemes for diffusion equations with an obstacle term. IMA Journal of Numerical Analysis, Oxford University Press (OUP), In press, ⟨10.1093/imanum/draa014⟩. ⟨hal-01686742v2⟩
Share
Metrics
Record views
605
Files downloads
1182
