A posteriori error estimates and stopping criteria for space-time domain decomposition for two-phase flow between different rock types. in revision, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01540956
A reduced fracture model for two-phase flow with different rock types, Math. Comput. Simulation, vol.137, pp.49-70, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01249322
A posteriori error estimation for lowest order Raviart-Thomas mixed finite elements, SIAM J. Sci. Comput, pp.189-204, 2007. ,
A posteriori error estimates and stopping criteria for solvers using the domain decomposition method and with local time stepping, theses, Université Pierre et Marie Curie-Paris VI, 2017. ,
A multipoint stress mixed finite element method for elasticity I: Simplicial grids, 2018. ,
A multipoint stress mixed finite element method for elasticity II, Quadrilateral grids, 2018. ,
A Lagrange multiplier method for a Stokes-Biot fluid-poroelastic structure interaction model, Numer. Math, vol.140, pp.513-553, 2018. ,
On the implementation of mixed methods as nonconforming methods for second-order elliptic problems, Math. Comp, vol.64, pp.943-972, 1995. ,
Mixed and nonconforming finite element methods: implementation, postprocessing and error estimates, RAIRO Modél. Math. Anal. Numér, vol.19, pp.7-32, 1985. ,
Mixed finite element methods for linear elasticity with weakly imposed symmetry, Math. Comp, vol.76, pp.1699-1723, 2007. ,
Mixed finite elements for elasticity, Numer. Math, vol.92, pp.401-419, 2002. ,
Weakly imposed symmetry and robust preconditioners for Biot's consolidation model, Comput. Methods Appl. Math, vol.17, pp.377-396, 2017. ,
Space-time finite element approximation of the Biot poroelasticity system with iterative coupling, Comput. Methods Appl. Mech. Engrg, vol.320, pp.745-768, 2017. ,
Stabilized lowest-order finite element approximation for linear three-field poroelasticity, SIAM J. Sci. Comput, vol.37, pp.2222-2245, 2015. ,
Theory of elasticity and consolidation for a porous anisotropic solid, J. Appl. Phys, vol.26, pp.182-185, 1955. ,
URL : https://hal.archives-ouvertes.fr/hal-01368659
Coupled multiphase flow and poromechanics: A computational model of pore pressure effects on fault slip and earthquake triggering, Water Resour. Res, vol.50, pp.3776-3808, 2014. ,
A nonconforming high-order method for the Biot problem on general meshes, SIAM J. Sci. Comput, pp.1508-1537, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01162976
Analysis of finite element approximation of evolution problems in mixed form, SIAM J. Numer. Anal, vol.42, pp.1502-1526, 2004. ,
Robust fixed stress splitting for Biot's equations in heterogeneous media, Appl. Math. Lett, vol.68, pp.101-108, 2017. ,
Anderson accelerated fixed-stress splitting schemes for consolidation of unsaturated porous media, Computers and Mathematics with Applications, 2018. ,
Well-posedness of the fully coupled quasi-static thermo-poroelastic equations with nonlinear convective transport, Journal of Mathematical Analysis and Applications, 2018. ,
Upscaling of the Coupling of Hydromechanical and Thermal Processes in a Quasi-static Poroelastic Medium, Transport in Porous Media, pp.1-22, 2018. ,
An a posteriori error estimate for vertex-centered finite volume discretizations of immiscible incompressible two-phase flow, Math. Comp, vol.83, pp.153-188, 2014. ,
Thermo-hydro-mechanical modeling of fluid geological storage by Godunov-mixed methods, Internat. J. Numer. Methods Engrg, vol.90, pp.988-1009, 2012. ,
Scalable algorithms for three-field mixed finite element coupled poromechanics, J. Comput. Phys, vol.327, pp.894-918, 2016. ,
An adaptive hp-refinement strategy with computable guaranteed bound on the error reduction factor, Comput. Math. Appl, pp.967-983, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01666763
A posteriori error estimates, stopping criteria, and adaptivity for multiphase compositional Darcy flows in porous media, J. Comput. Phys, vol.276, pp.163-187, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00839487
Adaptive regularization, linearization, and discretization and a posteriori error control for the two-phase Stefan problem, Math. Comp, vol.84, pp.153-186, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00690862
A framework for robust a posteriori error control in unsteady nonlinear advection-diffusion problems, SIAM J. Numer. Anal, vol.51, pp.773-793, 2013. ,
A posteriori error analysis of Euler-Galerkin approximations to coupled elliptic-parabolic problems, M2AN Math. Model. Numer. Anal, vol.43, pp.353-375, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00164851
A posteriori error estimation based on potential and flux reconstruction for the heat equation, SIAM J. Numer. Anal, vol.48, pp.198-223, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00383692
, Partial Differential Equations, vol.19, 1998.
Numerical simulation of blood flows through a porous interface, ESAIM: Mathematical Modelling and Numerical Analysis, vol.42, pp.961-990, 2008. ,
A unified framework for a posteriori error estimation for the Stokes problem, Numer. Math, vol.122, pp.725-769, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00470131
Finite volume methods for elasticity with weak symmetry, Internat. J. Numer. Methods Engrg, vol.112, pp.939-962, 2017. ,
Domain decomposition and multiscale mortar mixed finite element methods for linear elasticity with weak stress symmetry, 2017. ,
Guaranteed a posteriori error estimator for mixed finite element methods of linear elasticity with weak stress symmetry, SIAM J. Numer. Anal, vol.49, pp.2364-2385, 2011. ,
Robust error analysis of coupled mixed methods for Biot's consolidation model, J. Sci. Comput, vol.69, pp.610-632, 2016. ,
Parameter-robust discretization and preconditioning of Biot's consolidation model, SIAM J. Sci. Comput, vol.39, pp.1-24, 2017. ,
Mixed methods using standard conforming finite elements, Comput. Methods Appl. Mech. Engrg, vol.198, pp.680-692, 2009. ,
Energy norm a posteriori error estimates for mixed finite element methods, Math. Comp, vol.75, pp.1659-1674, 2006. ,
Elliptic reconstruction and a posteriori error estimates for parabolic problems, SIAM J. Numer. Anal, vol.41, pp.1585-1594, 2003. ,
Blood-flow modelling along and trough a braided multi-layer metallic stent, 2009. ,
Improved accuracy in finite element analysis of Biot's consolidation problem, Comput. Methods Appl. Mech. Engrg, vol.95, pp.359-382, 1992. ,
Stable cell-centered finite volume discretization for Biot equations, SIAM J. Numer. Anal, pp.942-968, 2016. ,
A coupling of mixed and continuous Galerkin finite element methods for poroelasticity. II. The discrete-in-time case, Comput. Geosci, vol.11, pp.145-158, 2007. ,
A coupling of mixed and discontinuous Galerkin finite-element methods for poroelasticity, Comput. Geosci, vol.12, pp.417-435, 2008. ,
Stress and flux reconstruction in Biot's poro-elasticity problem with application to a posteriori error analysis, Comput. Math. Appl, vol.73, pp.1593-1610, 2017. ,
Error analysis of primal discontinuous Galerkin methods for a mixed formulation of the Biot equations, Comput. Math. Appl, vol.73, pp.666-683, 2017. ,
A finite element framework for some mimetic finite difference discretizations, Comput. Math. Appl, pp.2661-2673, 2015. ,
, New stabilized discretizations for poroelasticity and the Stokes' equations, 2017.
Diffusion in poro-elastic media, J. Math. Anal. Appl, pp.310-340, 2000. ,
A coupling of weak Galerkin and mixed finite element methods for poroelasticity, Comput. Math. Appl, vol.73, pp.804-823, 2017. ,
A finite-volume discretization for deformation of fractured media, Comput. Geosci, vol.22, pp.993-1007, 2018. ,
The existence and uniqueness theorem in Biot's consolidation theory, Apl. Mat, vol.29, pp.194-211, 1984. ,
A posteriori error estimates for finite element discretizations of the heat equation, Calcolo, pp.195-212, 2003. ,
Unified primal formulation-based a priori and a posteriori error analysis of mixed finite element methods, Math. Comp, vol.79, pp.2001-2032, 2010. ,
A coupling of nonconforming and mixed finite element methods for Biot's consolidation model, Numer. Methods Partial Differential Equations, vol.29, pp.1749-1777, 2013. ,
Convergence analysis of a new mixed finite element method for Biot's consolidation model, Numer. Methods Partial Differential Equations, vol.30, pp.1189-1210, 2014. ,
