Adaptive Dual Color Visible Light Communication (VLC) System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
In this work, we propose a Visible Light Communication (VLC) system dynamically adapting, through a decision-making process based on a simple fuzzy-logic, the transmitting color selection to the external environmental conditions. Transmitted Signals are opportunisti-cally treated through softwarization approaches by using basic hardware (i.e. Arduino boards and inexpensive LEDs in the transmitting stage) in order to implement an effective, end-to-end, adaptive communication system. In particular, we will show that, if a low environmental noise is added, the system keeps to be well-performing in terms of Bit Error Rate (BER) also at higher distances (up to 8-9 meters) using a warm white front-end, while, if high external interfering lights are present in the environment , a low power red front end is dynamically fed for maintaining a good-level communication (with low Bit Error Rate).
camera-ready-adaptive.pdf (10.77 Mo) Télécharger le fichier
hal-01687543 , version 1 (18-01-2018)
  • HAL Id : hal-01687543 , version 1
Antonio Costanzo, Valeria Loscrì, Sandra Costanzo. Adaptive Dual Color Visible Light Communication (VLC) System. 6th World Conference on Information Systems and Technologies, Mar 2018, Napoli, Italy. ⟨hal-01687543⟩
Collections
INRIA INRIA2
368 Consultations
243 Téléchargements
